Durango DEX210 Thread
could be a couple things on your set up, more anti squate or softer spring/shock set up would be the first thing I'd try, I find diff oil plays with the overal rotation of the car, but with set up, just try something, if it doesn't work, change it back and try again.
The front c-hub setting is not so much affected by the longitudinal shift of the ball-stud so don't worry too much about that. It is primarily when you get an off set in height that needs to be paid attention too.
Thanks, currently running zero anti squat. How is it measured? Have seen numbers on setup sheets that I don't understand.
Im completely sold on this ready to run chassis. Threaded shocks, a ball diff, Speed Passion 13.5 brushless system, and the stock radio doesnt look that bad either.
My favorite part there's a deans end on the speed controller. Thats all I run is deans.
This chassis is less expensive than the bandit VXL. And the bandit VXL isnt considered a racer.
They have one in stock at my local hobby shop. I hope it's still there.
Gonna pick it up tomorrow if it's still there.
Im completely sold on this ready to run chassis. Threaded shocks, a gear diff, Speed Passion 13.5 brushless system, and the stock radio doesnt look that bad either.
If you can swing it, I'd recommend getting a flysky gt3c. The stock receiver binds right to it.
That's fine with me. Does the shocks have oil in them and does the diff have fluid already in it? I also like to have a bit of grease on my gears too inside the transmission. I probably wont change shock oil right away because it might
run fine with the stock oil and grease. Im not going to change springs either
unless I absoultely have to. Since the shocks are threaded you can change that without having to buy springs sometimes.
The stock diff comes with oil but the RTRs I've bought myself the and 4 that I've sold to various customers have all had the oil leaking out from the factory. Tear that bish down and fill it up with some black grease.
I run a gear diff in my buggy and the diff is filled with two whole tubes of black grease. I love it on the indoor clay tracks I race on...and the bumpy outdoor tracks too.
This was the case with a DESC210 that my friend got as well. It didn't look like oil leaked out though. Get the DEX408 shock O-Rings to stop leaks.
I have built using the stock w/o issues, I put a little grease on the O-rings when building then everything else normal.. no issues.
When you guys run the gear diff do you have the (2) gear or the full (4) gear in the diff?
