Durango DEX210 Thread >
Like Tree80Likes
Old 09-13-2013, 08:07 AM
  #12226
Question for those that have changed the stock ball cups to something different, did you have any issues with clearance in the rear camberlink near the spur gear? The stock one has a bend in it to clear the gear cover. How can it be replaced with a regular straight ball cup?
From pics, it looks like mid motor has less problems with clearance, but I'm running rear motor and it looks very tight.
jha07 is offline
Old 09-13-2013, 08:38 AM
  #12227
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Nope no issues just flip your hubs like I did in the picture.
Atomicsickness is offline
Old 09-13-2013, 08:51 AM
  #12228
Thanks for the tip. Are those losi 22 turnbuckles and cups?
jha07 is offline
Old 09-13-2013, 09:04 AM
  #12229
It is the Lunsford kit. Expensive, but I never have to worry about popping a cup.
I had a small run in with another car just after the landing of a double. The crash broke the carbon fiber steering rack and the ball cup never popped. Some say that is bad, but I like the peace of mind.
Old 09-13-2013, 05:17 PM
  #12230
tony montana's Avatar
Trader Rating: 76 (100%+)
what in millimeters should the slipper nut be set at roughly?
tony montana is offline
Old 09-13-2013, 05:41 PM
  #12231
Trader Rating: 57 (100%+)
Can't do it that way. We don't know your track conditions. That's something that needs to be set at a track and adjusted before the first run.
Some people like to do the front wheel lift but I like to adjust mines based on slip distance.
shagino is offline
Old 09-13-2013, 06:15 PM
  #12232
I use the front wheel lift method, so I can set it in the pits. I will then do adjustment on the track to fine tune.
I sugest to start on loose side and go tighter. It is easy to smoke a diff that is not broke in on the bench.
Old 09-13-2013, 07:31 PM
  #12233
What are your opinions on using thread locker on the tiny a** screws that thread into the shock pistons?
simonseize is offline
Old 09-13-2013, 08:08 PM
  #12234
I'm still having issues with my diff. It still seems to loose and it is almost fully tightend down. Not all the way but pretty close. Driving it on my driveway I can hear it barking slightly. Thought it was the slipper first but I have it cranked down pretty good.. should the diff be this tight?
Old 09-13-2013, 08:10 PM
  #12235
RC10Nick's Avatar
did you compress the spring before you installed it?
RC10Nick is offline
Old 09-13-2013, 08:12 PM
  #12236
Yeah I did.
Old 09-14-2013, 05:08 AM
  #12237
slammedwagon's Avatar
heres my 210 body I just finished
slammedwagon is offline
Old 09-14-2013, 05:16 AM
  #12238
RC10Nick's Avatar
Yeah I did.
hmmm... You may want to take it out, take it apart, clean it all up, flip the diff rings, and try again. Make sure to follow this video to a "t"
+ YouTube Video
RC10Nick is offline
Old 09-14-2013, 06:12 AM
  #12239
Get a high quality .050 or 1.3mm wrench. I've stripped that screw before and it sucks when that happens. I like the bleeder screws though. Shock building is a lot more consistent for me that way.
shagino is offline
Old 09-14-2013, 06:13 AM
  #12240
TLRNitroBasher's Avatar
How is the durability and how is the handling compared to the team associated b4's? Is one car better than the othe r
TLRNitroBasher is offline
