Durango DEX210 Thread
You mentioned a track. Which track would you go to? Perhaps someone here goes to that track. I'd check on their parts support. If you break and you can't fix it at the track, it's going to be really frustrating. Take a day and check the track out.
Have you ever built one? If now, the RTR is the way to go. Building a kit is a great experience but you'll need a lot of tools to do it properly.
As for the build, not scared of a build. I fly RC Helis exclusively and have built and rebuilt many. However, I know that building my own will be much pricier than $175 that Tower has this kit at.
I will need different tires, correct? Its a dirt track, maybe clay? Looked sticky. They were using a gas powered tamper as they had just rebuilt. I also don't know if I'll want to go MM immediately, or if the gear box is fully adjustable MM3/4 RM3/4 like the pro.
I just bought a 210. I've been looking at it for a while and finally decided to buy one. Unfortunately I bought a used one 2 days before I saw the low price from Tower. Oops! Fortunately I still paid a little less and it is very lightly used. The chassis has maybe one little scratch so it was either driven very little or was mostly on carpet. Unfortunately whoever built it had no idea what they were doing. The front caster blocks had 3 spacers instead of 4 so the front was very loose and sloppy. The right front camber link was on the inner hole in the caster block but on the outer hole in the left one. It had full droop in back and hardly any up front. It also had negative static camber in the rear. The front had tons of bump steer due to the way it was setup as well. I'm just glad I didn't find lead weights everywhere to balance it all out! There are also 2 nearly stripped screws that took some patience to get out and the left front caster block has is stripped on the top hole for the steering block. There is also flashing still on every part. Some people should NOT be allowed to build RC cars! Fortunately I can fix it all but I wish I'd have waited 2 more days and seen the new low prices at Tower. The small monetary savings is more than offset by having to fix a few things. Fortunately they provided all of the extra parts with the car. Oh well. I've got it and now I'm going to play with it.
I am a huge proponent of mid motor but since I am custom building my own mid motor car I thought that I should have a good rear motor reference car to compare it to in order to determine if it works well or not. Time to start playing and tuning. I'm pretty busy so when I get some progress made on tuning I'll share my results.
R/C Tech Elite Member
Is Durango coming out with new 2wd and 4wd buggies? tower is sold out but their prices are dirt cheap.
read thru forum and u will find answer
The track is in Reynoldsburg, OH. It was called ENHobby, not Sparks. I was there a few days back, but didn't ask what they carry. Did speak with a guy who runs Durango...
Somewhere in between. An oople post mentions next Feb but there's no official announcement. Personally I believe it to be true but I also know that a new version would have cost at least twice as much as what it was going for.
Cool, I would enjoy reading and seeing what you come up with for set-up specs..
From what I've read and seen, there most likely will be a new 2wd in the works, the rumor mill says mid to late first quarter 2014... I'm sure the 1/10 worlds coming up will tell the tale...
As for the 410 getting an update, not sure. I know a lot of people seem to think it needs a longer chassis and new layout to accomodate electronics easier. In my opinion it is one of the best 4wd available as is..
I don't expect to see anything available to the public til early next summer, or they've done an excellent job of concealing there R&D and prototypes
p.s. you gotta love those folks on here that are so helpfull with there "if you want to know start reading" answers... Come on guys
so got my 210 in the mail. Couldnt beat the price from tower. Getting ready to start the build. Anyone have a decent setup for a low to medium at best traction outdoor setup? Also are most of you guys running shotry's or fullsize lipos?
slap a shorty in that thing, head on over to petitrc.com and check out all the tips/setups/links.
half the fun of the dingo is learning to do your own setups
I'm at 1.2x 4 hole all around 27.5 ae front 25 ae rear , and only single taper I wanted the down travel quicker and smoother but I wanted the pack for jumps it was super reactive and great to me I'm gonna go indoor with the same setup this year
You know, ball cups have been the bane of my existence since the original RC10 in 1985. You'd think that times would have improved things. I'm converting over to the ball cups from the 22. I did on my other cars and have had no problems on them since. These are pure junk and have got to go.
