Durango DEX210 Thread >
Like Tree80Likes
Old 08-01-2013, 06:09 AM
  #11761
AP3XMONK3Y's Avatar
ttt
AP3XMONK3Y is offline
Old 08-01-2013, 07:05 AM
  #11762
Trader Rating: 57 (100%+)
Does anyone have a chart of pinion/spur combinations? Like 26 is the smallest I can go with a 75 spur. 25 looks like it may work but I'm not comfortable with the mesh.
shagino is offline
Old 08-01-2013, 09:00 AM
  #11763
DangerCow's Avatar
Originally Posted by lil_man72
how are the aluminum towers? does the added weight that high up have any negative effects on the car?
I weighed all the towers before installing them and the aluminum ones were only a few grams heavier, so I didn't notice any difference.
DangerCow is offline
Old 08-01-2013, 09:02 AM
  #11764
DangerCow's Avatar
Originally Posted by Woulvesbaine
Love the Alitalia scheme. Did you paint that?
Ya thanks, and no paint, it's a vinyl wrap from RC Tagz (he also did one for my Exo and DEX410).
Old 08-01-2013, 09:05 AM
  #11765
Trader Rating: 19 (100%+)
Yeah, the mesh on a 75/25 is less than ideal. 78/26 will get you nearly the same ratio and a good mesh. Question is, what motor are you gearing that way?
Jonny5 is offline
Old 08-01-2013, 09:23 AM
  #11766
Hey Jonny,
I actually posted this in the wrong thread. It's for my SC when I run at streamwood. Coming off a little hotter than I want with a 26. Since it's the same transmission, I left the post here. Was more for my info not a specific case.
shagino is offline
Old 08-01-2013, 09:36 PM
  #11767
lil_man72's Avatar
Trader Rating: 29 (100%+)
thanks, that's what i needed to know. i've already got a rtr that i plan on upgrading but i'm also on the lookout for a used one with upgrades already added. i'm planning on ending up with 3 or 4 buggies total since i'll be building a couple oval cars setup mm with the buggies.
lil_man72 is offline
Old 08-02-2013, 08:10 PM
  #11768
platgof's Avatar
I put metal washers on the top of the shock towers to take the beating, and replace them when they wear out. I had to move weight to the rear running mm3 to get a good jump. Same problem with my ST210. They would nose dive with fwd weight.
platgof is offline
Old 08-03-2013, 04:22 PM
  #11769
Trader Rating: 125 (100%+)
Fresh paint...
kwiksi is offline
Old 08-03-2013, 11:53 PM
  #11770
Azagar's Avatar
Who does your decals Kwiksi?
Azagar is offline
Old 08-04-2013, 05:10 AM
  #11771
http://www.s1racing.net/
kwiksi is offline
Old 08-04-2013, 10:14 AM
  #11772
DangerCow's Avatar
Originally Posted by wyd
One thing I noticed vs the other brand cars I have run is when you look at many different setups the Durango ones are all over the place and you don't see many common setups. Only thing seems common is pretty much the camber link postions and shock positions. Oils, pistons, springs, and battery placements are all over the place.
Sooo...what are the common camber and shock positions?
Old 08-04-2013, 04:00 PM
  #11773
Hazzmatt1's Avatar
Default Ball Diff
I took my ball diff apart and was wondering if a wear ring around the pressure plates is normal. I have wear on both sides where the balls contact the plate. I would post a picture but I'm not in the picture posting club yet.
Matt
Hazzmatt1 is offline
Old 08-04-2013, 06:22 PM
  #11774
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Front camber link hole #2 inside and #1 outside
Rear camber link stock hole on tranny case and #3 on hub.
Front shocks #2 on tower and #1 on arm
Rear shocks #2 on tower and #2 on arm.
Now these are what I noticed seemed to be the most common for medium traction to high traction clay tracks which is what I normally run on. Not saying these are the best but when I was looking at a starting setup these postions looked to one of the most popular.
As for springs, pistons and oils they where a ton harder for me to decide on. Saw many different brand springs from Durango, Losi and Kyosho. Pistons where a lot of 4 hole and 6 hole.
wyd is offline
Old 08-04-2013, 08:37 PM
  #11775
DangerCow's Avatar
Thanks for that!
