Durango DEX210 Thread >
Like Tree80Likes
Old 10-22-2011, 10:32 AM
  #976
Team Tekin
Randy_Pike's Avatar
Originally Posted by Matt Howard
I understand the need to be different, but why did Durango go with 14mm hexes when the rest of the industry is now using 12mm? Hopefully someone will come out with some kind of adaptor, LHS doesn't usually stock Durango parts so getting Losi or AE hex rims will be alot easier than myself stocking up on Durango rims. Wait, maybe that's why they did it, so I would have to stock up on rims
You can use the rear pin and spacer set from the 4wd and use B4 wheels if you want. I've been doing this to use the 4wd rear buggy wheels.
Guys trust me the larger hexes are needed. I've stripped out wheels before at the 12mm size. Especially fronts on the 4wd on high bite tracks. Understand that this car is designed at the world level, not just U.S. If you've ever driven on turf the bite they get is phenomenal.
Also the larger hex should help prevent wobbling and offers a larger mating face to the wheel.
Randy_Pike is offline
Old 10-22-2011, 11:13 AM
  #977
Glowster21's Avatar
Trader Rating: 136 (100%+)
Originally Posted by Cpt.America
I'm tellin ya.. i couldn't disagree more... its going to be a pain in the butt working on the diff (even putting it together) without them. Heck, I had to take it out once putting it together the first time.
I used to run Corally sedans and we had the snap rings on the diffs. First couple times you struggle but once you get the feel for the clips they're easy to work with.
Glowster21 is offline
  #978
onekiwi's Avatar
But thats for the rears only right?
Cpt America: get one of the clips with a big circle as a head then bend it a little, that way you and I can still grip the clip and get it on all at the same time
onekiwi is offline
Old 10-22-2011, 12:42 PM
  #979
jzemaxx's Avatar
Originally Posted by JayBuc
So far how does the dex210 compare to the tlr 22? I buy one of them tomorrow
Good question. I'm interested in rear traction vs the two. Especially with the rm4 setup of the dex, but the losi has the longer wheelbase.
jzemaxx is offline
Old 10-22-2011, 02:18 PM
  #980
Just got my 210 kit! Can't wait to get started....should I use 450 shock oil?
JayBuc is offline
Old 10-22-2011, 02:38 PM
  #981
twelvegauge's Avatar
Default diff problemz
Still having problems. Diff is built correctly and tight still slipping. I ground down the nub on one outdrive and it helped a little.
twelvegauge is offline
Old 10-22-2011, 04:36 PM
  #982
Team Tekin
Randy_Pike's Avatar
Time to take it apart, post some pics of all the parts layed out please.
This is a simple diff to build. There is only one loose shim that could be missed. IF trimming the outdrive "nub" helped then the thrust assembly isn't full seated.
Old 10-22-2011, 04:55 PM
  #983
I pulled the trigger on the 210 today. My LHS had one left...I hope Its good
JayBuc is offline
Old 10-22-2011, 05:06 PM
  #984
jzemaxx's Avatar
Let me know. I am ready to pull the trigger on one of these.
jzemaxx is offline
Old 10-22-2011, 05:15 PM
  #985
trx-1racer's Avatar
The rm4 will likely offer about as much rear bite as you can get in a 2wd car. The problem is keeping enough on power steering to make it really useful. I talked to Fischer today and he really likes the rm3 setup the best.
As for the wheelbase, the car was designed around world distribution first, but I suspect they will address the longer wheelbase for US tracks relatively soon.
Here is a couple shots of Fish Daddy's car with the lid off:
trx-1racer is offline
Old 10-22-2011, 06:08 PM
  #986
Slash'em1's Avatar
I will have my 210 this Tueday. I should have just paid the $20 to get it faster. oh well its giving me time to read all the tips. I haven't drove a 2 wheel drive buggy since 1993. I still need to buy tires. What would be a good tire for a high bite clay track?
Slash'em1 is offline
Old 10-22-2011, 06:23 PM
  #987
rcman182006's Avatar
Trader Rating: 15 (100%+)
Losi Pink Tapers or BK bars
Hot Bodies Pink Beams and Fullshots
Proline MC Suburbs and Scrubs
JCon Green Barcodes (I don't use Jcon tires a lot)
Panther Clay Switches
any of the AKA tires for buggy should work too in Super Soft Compound
rcman182006 is offline
Old 10-22-2011, 06:35 PM
  #988
What do you mean longer wheelbase?
JayBuc is offline
Old 10-22-2011, 06:44 PM
  #989
Slash'em1's Avatar
Thanks rcman
  #990
teeforb's Avatar
Trader Rating: 94 (100%+)
So far!
teeforb is offline
