Durango DEX210 Thread
#7471
Put the kit together, started to adjust the turnbuckles and three of them kept popping off the ball cups. I pre-threaded them, used some grease before putting them together, installed them on the ball ends once, did not stick anything through the hole when threading them together... really disappointed.
I am going to have to test the buggy with these ball cups on there, but I anticipate turnbuckles popping off for sure.
#7472
Hi All!
New 210 parts came in this week;
http://www.exotekracing.com/latest-products/
Alloy shock caps are due late Sept!
#7473
Front Hex Mod
Stealing the idea from Jeremy Harris. Thanks man!
Here are the parts I used.
Team Durango Steering Knuckle Set (2) [TDR330382]
Kyosho Steel Axle Shaft Set (RB5 WC) (2) [KYOUM569]
Team Durango 5x10x4mm Ball Bearing Set (4) [TDR601002]
Kyosho 5x7mm Aluminum Servo Saver Collar Set (Blue) (4)[KYOW0149]
The axial was a little to long for me so I cut them down. Below you can see one that I cut and one uncut. It is a pretty easy mod. Took me about 15 min cutting down the axials.
#7476
#7477
#7478
Loving the step by step pics!!
#7480
I'm planning on running this car over the winter. What are some suggested hop ups if any? Also should I pick up other springs? And what pinion do you suggest with an Orion 8.5 using the stock spur?
I'll be running indoor on a tight track with med to high bite and normal size jumps.
Thanks in advance. I'm really looking forward to running this car.
#7481
#7482
I'm planning on running this car over the winter. What are some suggested hop ups if any? I.e. alumn rear hubs, different shock towers, etc....
-Do I need a low profile servo or will say a Futaba 451 work?
-Do I need a shorty pack such as the Trakpower 4400 shorty?
Sorry for all the questions, just want to cover all my bases... Or most of them!
#7483
http://www.tresrey-usa.com/tresrey-a...ex210-dest210/
http://www.tresrey-usa.com/tresrey-d...teering-plate/
Add to that some CF front and rear towers and the car is about bulletproof.
Stock springs are suited more for MM setup, so if you plan on running RM I would get the next couple firmer for the rear and softer for the front. If I remember right we had dk green rear and Black front.
#7485
Gearing u will have to play with some but watch your temps. I run a 10.5 and am using 25/78 gearing. That's fine for me now.
Servo, standard is fine.
Battery, TrakPower shorty is an awesome battery. That's what I run. It gives you room for weight adjustment, by moving it forward or back. Just need to add foam to the tray. I run mine all the way forward.
