Durango DEX210 Thread
#7456
Hey guys. At my last race meet I was screwing in the front pivot ball on the inner of the front link and it shattered. I needed to use pliers to screw it out.. So is there a mod you guys are using to go better? Changing brands? Or was this a freak accident and just buy another TD one?
Cheers
Cheers
#7457
Cheers
Cheers
#7458
The 25T pinion with the 76T spur should be just fine for you. Hope that helps some.
Best thing to do is play with gearing to see where you feel comfortable at. But always keep an eye on temps.
Good luck
#7459
Since my local shop does not stock parts I am placing an order for extras and back up parts. What do you guys suggest I stock up on?
I already have extra arms and towers, etc. What else? Axles, shock shafts, hubs, motor plate, gear cover, any of that sort of thing? I don't want to over do it. Just enough to get by until I evaluate the buggy.
Are any of the parts interchangeable with Losi or AE? I already picked up some B4 slipper pads, because those are a direct fit. Anything else swappable?
#7460
Nothing esle is interchangeable with those other buggies.
#7461
What does rebound do for the car as far as handling like bumps and jumps and turns thnx
#7462
Hi All!
New 210 parts came in this week;
http://www.exotekracing.com/latest-products/
Alloy shock caps are due late Sept!
#7463
Hi !
Wrote a couple of days ago about a Ballistic 8.5 that didn`t have either punch nor speed any longer. Was advised to try a new motor so today I tried a new Ballistic 6.5 with 83/21 gearing and no fan on the esc. Temperature outside was +10 celsius.
The car was fast but not uncontrolable and after 4min the esc thermaled and the motor was also very hot, but I could hold my hand on it atleast 15sec.
Do I really need fan on the Xerun 120a esc in a 2wd or is there something wrong with the esc also ?
#7464
Hi All!
#7465
Hi All!
#7466
Wow, looks some nice parts there!
#7468
#7470
Put the kit together, started to adjust the turnbuckles and three of them kept popping off the ball cups. I pre-threaded them, used some grease before putting them together, installed them on the ball ends once, did not stick anything through the hole when threading them together... really disappointed.
I am going to have to test the buggy with these ball cups on there, but I anticipate turnbuckles popping off for sure.
