Durango DEX210 Thread >
Like Tree80Likes
Old 11-18-2011, 10:56 AM
  #2071
Trader Rating: 19 (100%+)
Originally Posted by Dammit138
I'm working on parts list so I can save up some $$ to buy my kit and I'm stuck on servos. What's everyone using? I've used Hitec in the past and while they were great they were expensive. I'm considering Savox.
We're running the Savox 1258 TG in all of Cush's rigs with great result. Smooth, fast, plenty of torque, and reasonably priced. Pretty sure you can get one for under $80. Tresrey USA is now stocking them are prices are right in line with other major sources.
Jonny5 is offline
Old 11-18-2011, 10:57 AM
  #2072
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
You could always check out the Classified section. I've had great luck with the Orion and Futaba servos that I've purchased there.
That said, the Savox servos get the job done.
t0p_sh0tta is offline
Old 11-18-2011, 10:59 AM
  #2073
Trader Rating: 25 (100%+)
Savox servos are really nice servos for the price. The 1258 or 1257 both are really nice for this car.
KainK is offline
Old 11-18-2011, 11:29 AM
  #2074
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Savox servos are the best bang for the buck, but they are not the best servos. They draw more power than most other servos which can cause issues with some radio systems, they are noisy, and they are orange!
I have been using the BLS series servos from futaba for the last couple years, and wouldn't run anything else. They are expensive, but what i can't stress enough is, if there is one place on the car where you DONT want to skimp, it's your steering servo.
Iv driven the upper end savox back to back against my bls351, and the bls351 is much better.
Cpt.America is offline
Old 11-18-2011, 12:12 PM
  #2075
jannedwr's Avatar
Ok!
I´m new on 1/10 and havent got my 210 yet, so the BLS351 will fit in the dex210??
jannedwr is offline
Old 11-18-2011, 12:21 PM
  #2076
rcman182006's Avatar
Trader Rating: 15 (100%+)
Im planning on running an Airtronics 359
You can pick them up for around 50-60 bucks on eBay
rcman182006 is offline
Old 11-18-2011, 12:29 PM
  #2077
I guess the main thing I wanted to take away from this is that I can use a full size servo. I don't have to stick with a low profile version.
Dammit138 is offline
Old 11-18-2011, 12:49 PM
  #2078
Matt Howard's Avatar
yes, full size servo's can be used, even in mid motor configuration.
Matt Howard is offline
Old 11-18-2011, 01:00 PM
  #2079
Originally Posted by jannedwr
Ok!
Yep.. the BLS351 is the only servo I run
yep... full size no matter the config.
Old 11-18-2011, 01:07 PM
  #2080
jannedwr's Avatar
Ok, perfect, $100 saved there!
Just hoping to get my 210 soon, missing another race this weekend!
jannedwr is offline
Old 11-18-2011, 01:15 PM
  #2081
Rdog's Avatar
Trader Rating: 83 (100%+)
Just finished the initial assembly of my kit, gotta paint the body and install the electroics. Where are you guys at for a 17.5 motor for gearing. I only have the stock spur for now. I plan on ordering the RW spurs soon. Thanks in advance guys.
Rdog is offline
Old 11-18-2011, 01:36 PM
  #2082
Unless you plan to run a full boost setup on it I would not even attempt to run a 17.5 with the stock spur. Get an RW 69 tooth with a 30 (referenced from the NovaGear app) for blinky 17.5. I have always found the app to be a good way of getting a solid starting point for no timing gearing. As always, check your temps and adjust accordingly.
Jonny5 is offline
Old 11-18-2011, 01:55 PM
  #2083
Slash'em1's Avatar
I was also wondering about gearing with a 17.5 motor but got a RW 75 tooth spur. What would be a good starting point?
Slash'em1 is offline
Old 11-18-2011, 01:58 PM
  #2084
32-33. Not sure it will fit- Cush runs an 8.5 so the only gears we have run are an 81 and the stock 87.
Jonny5 is offline
Old 11-18-2011, 02:03 PM
  #2085
goBezerk's Avatar
I got a little bored of waiting for the real thing to turn up, so I just made my own
goBezerk is offline
