Durango DEX210 Thread
I'd go back to an RM3 setup for that track. Shorty battery half way forward. Look up balance tuning and then learn how to do it.
So i found out today why i had no steering! My axle was bent and was letting the wheel rub the caster block, how i didn't notice i couldn't tell you. I changed it out and good lord it feels like a new car. Thanks for the input guys
That's impressive, was it bent or not not seated in the insert? Never seen an axle bend but there's a first for everything
The axle itself was bent, i never recall ever hitting something hard enough to damage a part like that but you never know. Weirder things have happened. I checked the insert and it seemed indented upward like it had an obvious impact so i switched that out too
Does anyone know if the V2 chassis will fit on the V1 car? Exotek has a awesome carbon chassis and i was wanting to get it for stock racing
For the most part, yes. When going from v1 to v2 you need v2 sidepods. Going to a Type B v2 Dimec chassis presents it's own set of parts that have to be mildly modded or changed (front bulkhead, rear bumper and suspension hangers), but with the Exotek you shouldn't have that problem.
Also worth checking out is the PlanB custom alum chassis setup. This gives you the wide shorty pack setup that is similar to the B5. I believe it is similar in price to the Exotek. Let me know if you need more info.
Has anyone experienced breaking the regular plastic pistons? I seem to break the top portion where the screw holds the piston to the shaft. Should I be using a washer on top and underneath? Do I need to add a spacer on the outside so the shaft doesn't penetrate too far? This seems to be a regular occurrence. Is it because I am not using the bladders? I've been using the plastic shock caps for a while. This seems to happen on both my 210 and 410....Thanks!
-Wanderer
Do you have the rubber bump stops on the shock shaft outside the body and the small washer under the piston?
@rcjunky: yes to the rubber cone bump stop washers on the outside, and also yes to the washer under the piston. I'm breaking the top portion of the piston.
@wanderer: I'll double check that the pistons don't come up that far, and I don't think they do. It's just a bit curious how it's happening. I guess it's possible I'm over-torqueing the top screw but I have also had trouble with them coming loose. I also use loctite.
open to ideas, thanks!
Tim
Then, I would check the insert and spacers at the bottom of the shock. If you haven't replaced them in a while, the dirt trapped between the spacers and orings on the bottom of the shock and wear will cause excessive wobble on the piston shaft leading to the piston scratching the inside of the shock body and perhaps getting jammed somehow and breaking.
so just weighed the gear diff vs ball diff and the geardiff is around 10g lighter (28 vs 38g or something on top of my head).
i run on a outdoor mid traction track, do you think you will get any problems in a 17.5t diffing out?
