Durango DEX210 Thread >
Like Tree80Likes
Old 10-22-2014, 01:50 PM
  #15256
Trader Rating: 18 (100%+)
Originally Posted by Dino_D
start with 1-2k. Start with 2k first. I find the ball diff better on med traction tracks. Gear diff if high traction or carpet.
Thanks for the info, its medium at the start of the day then the traction goes up like most tracks. Its a new layout with fresh new clay, i would say in a month or so after more race days the traction will go way up and I'll look into switching then.
I will stick with the ball diff for a bit until the traction goes up. thanks for the reply tho
BensPro2 is offline
Old 10-22-2014, 02:53 PM
  #15257
Pittster's Avatar
So I went ahead and ordered 2x Exotek RF Alloy block's with the adjustable shims. From what I can see its no bigger than the normal RF block from durango but is anyone actually using these in a composite Type B chassis ? I have them in my dex210 and desc210. I will probably answer my own question when I get them but just wondering.
http://www.exotekracing.com/dex210-r...ith-shims-lrc/
Pittster is offline
Old 10-22-2014, 04:58 PM
  #15258
rcjunky1's Avatar
I have been, it takes some dremel work on the shims to fit without moding the chassis.
rcjunky1 is offline
Old 10-22-2014, 05:00 PM
  #15259
Pittster's Avatar
Hmm I kind of suspected that from that little overhang on the shims, but the actual block fits OK? I can file the edges of the shims easy enough
Pittster is offline
Old 10-22-2014, 06:31 PM
  #15260
rcjunky1's Avatar
Yup, just buzz off the little tabs off the shims and you're good
rcjunky1 is offline
Old 10-22-2014, 08:54 PM
  #15261
13Maschine's Avatar
are you guys running plastic gears in the gear diff? or metal?
13Maschine is offline
Old 10-22-2014, 11:36 PM
  #15262
Tech Prophet
tc5 man's Avatar
Im going to use the Metal ones that came with the diff gear. Not so sure on the plastic cross bars and gears inless they are pretty good quality.
tc5 man is offline
Old 10-23-2014, 12:37 AM
  #15263
Pittster's Avatar
I am running plastic ones in my dex410 with 8.5 and my Desc210 with a 10.5 no issues so far
Pittster is offline
Old 10-23-2014, 04:13 AM
  #15264
rcjunky1's Avatar
Yup, I ran plastic for motorama (stock class) and the beginning of the season (mod), durability is no issue with them
rcjunky1 is offline
Old 10-23-2014, 05:02 AM
  #15265
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by tc5 man
I meant to ask about what weight diff oil for the gear diff ? I'm thinking 4000w, 5000w since il be running on carpet and clay .
5k inside and high bite clay is great,, 2-3k for low/med bite
Careful w/ that exotek F/R hanger in mid motor config, if you don't use those center screws and the spacer plates WILL fall out.... After loosing two I just use gold washers to space it in my MM config.
8ight-e is offline
Old 10-23-2014, 06:52 AM
  #15266
Tech Prophet
tc5 man's Avatar
Ok il start with 5k in the rear diff thinking it should work on carpet fine also . Il take a try at them plastic gears and crossbars surprised they hold up with mod motors .
tc5 man is offline
Old 10-23-2014, 06:54 AM
  #15267
fq06's Avatar
Trader Rating: 12 (100%+)
They have been in my stock motor buggy since they came out. No issues with them.
fq06 is offline
Old 10-23-2014, 08:49 AM
  #15268
rcjunky1's Avatar
The plastic gears are so tough I'd try them in a desc410 if I had one
rcjunky1 is offline
Old 10-23-2014, 10:43 AM
  #15269
Devin's Avatar
I would just get the gear diff i just bought one . Since you gotta rebuild the ball diff .
The gear diff is a useless turd on my track. I tried one in my desc210. Even after we installed the watering system, not enough grip to make use of it. All the fast guys are ball diffs. It was weird, it handled best with 5K diff oil on our loose track rather than something low. Ball diff was just unquestionably better. I think we have one gear diff in a losi and that's it.
What that said, what does a ball rebuild entail? Do people normally re-use the balls? I am putting in new bearings for sure. Does the race thrust cage part get replaced as well, or am I OK to reuse it with maybe some new grease?
Devin is offline
Old 10-23-2014, 10:49 AM
  #15270
fq06's Avatar
The balls wear and get flat spots so replace the balls and the rings. Don't forget the balls that ride in the diff outdrive cup either.
I serviced and replaced every hand full of days driving. If there is any crunchyness to it I would replace. If it wasn't too bad i would clean and flip the rings.
fq06 is offline
