Schumacher Corner
Originally Posted by AdrianM
1. Is there a rear toe adjustment? (inboard or outboard)?
Jon is right on. The rubber car comes with 2deg and that is all we ever seem to run everywhere we go. You can get a set of U2450 plastic suspension mounts and they will let you hit 1.5 deg and 3 deg. However, like I said, we never run those.
The Foam car comes with 1.5 deg toe out of the box
Adrian: What mounts does the foam car come with? Will there be any .5 or 1 degree outboard toe-in rear hubs for the EC carpet car?
The riserplate and the chassie is missing a hole for the plastic ones, but I guess it would "work" using em' anyway, just a bit risky.
Hmmm...thats interesting. The foam car as both holes so you can use the plastic suspension mounts if you want to. I didn't know they ommitted the inner hole on the standard EC. The plastic mounts would still work though.
The mounts are the same. The holes on the chassis have been adjusted for less toe on the foam car. We have mentioned hubs with outboard toe to Schu UK but I am not sure when or if they will happen.
The foam car as both holes so you can use the plastic suspension mounts if you want to. [/b]
Adrian[/b]
Adrian[/b]
Originally Posted by Gee M
We should be able to have just over 1 degree inboard toe in then if the longer Alloy Cat mounts are used on the inside holes of the USA car.
That worked on the old car. On the new Foam spec you might end up with a touch of toe out doing that
Originally Posted by Jon Kerr
There's actually 2. High and Low. Any finer tuning than that can be done with shims on the hubs.
Adrian, if the foam spec has half a degree less built in inboard toe than the standard EC(and Mi-2) those mounts should then give close to .7 degrees then?
I dont think adding more than a .5 shim on the hub is possible using the included hub, ball grippas and standard dish rim? We can fine tune the inner links even more by getting thinner or thicker riser plate kits.
I measured the toe on the Carpet spec. It has about 1 to 1.5 per side.
The EC is still undefeated in Canada. TQ and win in stock rubber and TQ and win 19t rubber. Thanks Schumacher, cant wait for the North America Spec, haha!!!
Hey you must of pre ordered them. I'm still waiting for them to be avail to the dist. here on the west coast.
Just wanted to check that I have built the car correctly so far. I have insatlled the (FRONT & REAR) lower pivot mounts (purple alloy ones) and they are marked "L" and "R". It doesn't clearly state in the instructions which side they should go on. I tried putting both "L" on the same side and the same for the ones marked with and "R" but this produced a uneven hinge pin.
I then went and installed one "L" and one "R" on the left side and the same goes for the right side. Is this correct? Or am I missing something?
Other than this, the car has gone together extremely well. Very happy with the build quality so far.
Welcome to the team!!! I picked mine up today too, but haven't started it yet.
Iain
Originally Posted by bob33
i did the same thing as u wen building it. but then i realised it was wrong wen i could not get the front droop to be what i want . then got the instructions of a mate). u put them on as it u was looking at wishbone from the side. so yes u end up with a "L" and a "R" on each side of the car. all leter face down! and the square edges faces into the center of the car...........hope that helped and i dint confuse it to much
Originally Posted by Iain
Hey Lenny,
Iain
Iain
You got it early this morning!!! What have you been doing all day??? Work doesn't count!!! There is no excuse young Iain.
And YES, I am now a Schuie man!!!
Why NOT????
MO- I think I might change the colors again. I may save pink for the nats. Remeber the purple/green/white body???? That was looking pretty nice in my head last night. Maybe I'll paint up two
EC IN DA HIZZZZOUSE
EC IN DA HIZZZZOUSE
