Schumacher Corner
#9211
Hey Hector where did you get the pic of the dancing fat guy
#9212
1mm shims
are using plastic or metal shims for the roll center? where can i get some? do you use those same shims on the new rear carriers?
#9213
Re: 1mm shims
click here http://www.racing-cars.com/usa/main.asp Then type "washer" in the advance search box and select "TakeOff" in the manufacture field
#9214
thank you paul, i will try to order them soon.
#9215
Hi
Would anybody be able to provide me with a starter setup for asphalt. im using a 27 turn.
Thx in advance
[email protected] - if you want to email me a set up
Thx in advance
#9216
Originally posted by Hixxy
Hi
Thx in advance
Hi
Thx in advance
#9217
Originally posted by PW
Which car do you have...Mi2, Mission or older?
Cheers, and thanks in advance
Crashmaster
#9218
Thanks crashmaster....Mail has been sent
#9219
Nice one mate
Cheers
Crashmaster
Cheers
Crashmaster
#9220
MISSION SETUP
BTW. That setup really helped the car a lot Paul. Unfortunately before we could make 2 laps the rain came down at TQ so i wasnt able to fine tune any. The car felt good even without aditive on the tire. Was a little loose but i expected that since i got there only minutes before my heat started and didnt have time to stickum up. I think the major difference was that i was using a much softer oil than 40 and it made the car to soft. Once i up'ed the oil and use two holes for the shocks instead of three the car felt a lot better. Who would have thunk it because my MI2 rocks with the softer oil but i guess i have to keep in mind that these are two very differnt reacting cars.
Either way thanks again,
#9221
Hey guys,
Fairly new to RC and just bought a second hand MI2. Wanted to know a good setup. I'll only be running in 540 and on a concrete surface.
Cheers,
Shags
Cheers,
Shags
#9223
I've PM'd you.
Cheers,
Shags
Cheers,
Shags
