Schumacher Corner
#7864
your bending steel CVDS?...omg.
you win teh award for the first!...
I have snapped diff outdrives before tweaking one of those mutha's
#7867
Adam, Is it the actual bone that is bending??
I haven't personally ever seen any of the Steel MIP CVD's bend. This is the main reason they are used in the gas car as they were the strongest driveshaft they could find.
A coupld of things that might be worth thinking about though. Try running a little less steering lock. Personally i actually have a 1- 1.5mm spacter glued onto the hub to ensure a little less lock. This will put less side load on the CVD. ALso it is worth ensuring that they are free moving all the way through the pivoting. Can't see how this would be a problem, but you never know I guess.
Can't think of any other reason. I have used Titanium and Plastic (both weker than steel) and had no problems at all.
#7869
Jon Kerr:
You got PM, its a question about Mi2 set up.
#7873
new shocks
The worlds are about to begin so i wonder if there is any news about the new shocks?
And are there any other new products in delopment for the Mi2?
Arjen
Arjen
#7874
New shock will not be ready for the Worlds. Maybe before the Holidays.
The cars are remarkably stock. Most are running a Teemu chassis or a Teemu chassis with a tray.
They are running the rear body mounts on the rear tower...mostly for looks
Other than that you can get everything the team is running right now.
#7875
I have an question about those rear body mounts.
Do you have an picture about that mounting?
Can you tell me what i need to mount them also like that?
and do i need to drill something or?
Arjen
Arjen
