Schumacher Corner
#7562
Yeah...I need some myself They will ship in the next day or so. Probably be the middle of next week.
#7570
That Mazda 6 is too twitchy IMO. The car came alive when I switched to the stratus. On tighter tracks I like the alpha or the caddy. I threw a solid paint job on the car for this weekend as well. I heard that the track was pretty open so I don't think that I will be needing an aggressive body. I may bring the Mazda 6 just to show off the paint job....LOL
#7571
Hi Guys,
just want to post a quick note in here, we got some of the new Mi2 spools in stock, along with a couple of new hop-ups as well, including the Teemu chassis, sway bar kits and alloy suspension blocks
Steve Wang
Steve Wang
#7572
I'm running Teemu's LRP Masters setup with few changes:
-no roll bars
-AE blue springs rear
-rear shocks are on 2nd hole on tower and 2nd hole on arm (from outside)
-45wt (front) and 35wt (rear) and AE #2 piston
-4deg caster blocks
I'm going to try Teemu's setup on friday to see if it works better..
-no roll bars
-4deg caster blocks
#7573
body choices
#7574
Originally posted by mo
The Caddy has a little less steering and is much more stable. The rear wing mounts a little lower so you can run a larger wing and still be ROAR legal.
#7575
Originally posted by HarshGuy
How can you do that? ...at the nats we had to meaure the wing from one corner of the side dam to the opposing corner and it had to be a certain size (don't remember the size but I had to hack the hell out of my wing as did others), then the mesured from the front of the wing to the back of it, same thing, chad to be a certain size ...mounting lower wouldn't help that.
