Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 09-29-2004, 01:43 PM
  #7441
PW
PW's Avatar
Originally posted by TimPotter
PW, do you guys have a good Rubber carpet starting setup ?
I don't....I haven't run the car on carpet/rubber tire. I will probably start with my outdoor setup and tune from there
PW is offline
Old 09-29-2004, 01:52 PM
  #7442
coastaltony's Avatar
Trader Rating: 13 (100%+)
Paul, I just heard from an old racing buddy of yours. Glen Hammond needed a spare M8 so I sent him one.
coastaltony is offline
Old 09-29-2004, 01:55 PM
  #7443
PW
PW's Avatar
Thats awesome Tony
Here are a few things that I would probably do for carpet/rubber racing.
Next rate stiffer spring all around (gold fr & blue r).
Stiffer oil: 50 or 60wt front & 10 weight less in rear.
PW is offline
Old 09-29-2004, 03:26 PM
  #7444
RCGaryK's Avatar
Hey guys, I talked with PW today and something he mentioned today that just made soooo much sense that I wanted to share it. If you use the Aluminum hub carriers, it can be hard to make sure the hubs are spaced properly left to right with the plastic inserts. Trim the plastic insert down so it is flush with the sides of the hub and just use shims to get the wheelbase set right. with this setup you don't need to use the setscrew anymore too. I need to head to the HS tonight and get some shims and I will post some pics. Thanks again for the tip PW.
RCGaryK is offline
Old 09-29-2004, 03:59 PM
  #7445
Oasis2001's Avatar
Hey Matt,
Your points have been noted. Must get purple shock nuts. Black would suffice also and they are coming
As for the blue spacer, I normally run a silver 1mm one there. Last thing I did before the photo was put the blue 0.5mm one in. Typical!
Are you on ICQ ever these days? Been a while since we chatted. Have some Vantage questions aslo as I might get the new one in the next couple of weeks.
Oasis2001 is offline
Old 09-29-2004, 04:36 PM
  #7446
cornerspeed's Avatar
Hey Randy- Will you make me some Lexan .50mm and 1.00mm riser plates. Need them for the region 12 race. I take it the Teemu chassis was a virgin.
cornerspeed is offline
Old 09-29-2004, 04:54 PM
  #7447
Oasis2001's Avatar
Talking about ICQ and MSN etc. Maybe we can swap some numbers and start chatting!
ICQ-10373690
Im not on a great deal but would like to share some ideas etc.
Old 09-29-2004, 07:00 PM
  #7448
PW-Hector called me today and we fixed my tweak problem. He told me where to file down the motor mount and now the chassis is flat.
Adam Hartzell is offline
Old 09-29-2004, 07:37 PM
  #7449
Adrian
I just wanted to thank you again for your help with my missing part and the setup advice you gave me today on the phone. I have ran alot of different cars in the past few years, but with customer service like that I know without even having run my Mi2 yet that I have found a car/company that I will stick with for quite a while.
Thanks again
David
dway100 is offline
Old 09-29-2004, 07:44 PM
  #7450
Trader Rating: 32 (100%+)
Adam, what part the mount are you filing down if I may ask?
racenut123 is offline
Old 09-29-2004, 07:47 PM
  #7451
I ground down the front of the motor mount where it bolts to the top deck. Make sure that it no longer touches the top deck and leave the screw out.
Old 09-29-2004, 10:13 PM
  #7452
STLNLST's Avatar
I have the set up that I ran at the regionals last year. It was good enough for 3rd place in 19 turn . I'll get it posted tomorrow for those who may want to try it. I'll be trying Mo's standard asphalt set up this year on carpet.
STLNLST is offline
Old 09-29-2004, 10:24 PM
  #7453
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I only have .69mm lexan right now, need to find a place that sells it in metric widths, HobbyPeople doesnt anymore... Any ideas on who would locally?
Randy Caster is offline
Old 09-30-2004, 12:13 AM
  #7454
Chris, yeah an on a bit - i guess just not when you are!!! Drop me an e-mail if you like. Time difference doesn't become such an issue that way!! We're back at W London this weekend - looks like it might live up to it's other name though "Wet"
MattW is offline
Old 09-30-2004, 07:42 AM
  #7455
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Randy, call Ridout Plastics. 858-560-1551
Jon Kerr is offline
