Schumacher Corner
#4186
Originally posted by PW
Actually guys, the Schumacher springs are slightly more progressive than say AE or Xray. We seem to like the Schumacher springs outdoors and the others for indoors.
Quick note to all- I ran outside on asphalt at our club race last weekend, and there were 3 Missions (2 were mine). One of mine and the other one were running the basic asphalt setup I posted last fall. Find the setups here with the exception of red springs in the rear and less droop front and rear. I'll make the chenges to the setup sheet ASAP. I tried changing a few things, but I couldn't find anything better on our meduim bite track.
#4187
Trader Rating: 32 (100%+)
Hey guys check out this car that some French guys are playing with.....its part Schumacher..........
#4188
here are some more pic's........
#4189
some more.......
#4190
still more....
#4191
yep another one.......
#4192
hey paul, 100 to go to hit 100,000
#4193
SETUP!!!!
Hi i need to know what a very good setup would be for outdoor raicng its a very tight track without any straits !!! i am running brushless system so i will need like a mod motor setup!!!-please help need before tommrow's races!-gg and also it's a schumacher mission!!!
#4194
send some pics of your schumacher missions to me and some good setups! thanks-gg
#4195
1FastClub- if you had looked up 7 posts you would have seen a link to a setup page with some really good setups for different surfaces.
There is a reason for having forums where you leave all of the posts on them... so people can read back and find the information they need. If you don't find what you need after reading a bit, then you post your question.
Good luck at your race tomorrow.
#4196
I got custom chassis few weeks ago..It's 3mm thick with 2,5mm upper deck..Car is very stiff and way easier to tweak.Batteries are moved 11mm closer to center and layshaft+front one-way are turned around to get some room for batteries..I'll post some pics,if I have time..
#4198
Oasis: My guess is top over the bottom, but here in the states, if there are any ugly clouds in the sky, we usually don't race, and NEVER when its raining (although I wouldn't mind trying it once). I don't think its even possible to get the wet undertrays in the U.S. Good luck with that one...
#4200
oasis - i screwed mine to the chassis using the 4 "lower diff mounts" (the little things the bearings sit on), doing this just stops it rattling around when you are racing.
