Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 10-09-2002, 11:17 PM
  #3136
redsand's Avatar
Originally posted by minicooper
I've been using a solid front diff on my axis 2. It works really good on slippery tracks, it lets you go faster/deeper into a turn before you brake. Actually that's how I've been using it on all surfaces. No problems with breaking axles (lucky?)
Why would you run a solid axel up front ? Would that make the car have more on power steering exiting a corner ?
redsand is offline
Old 10-09-2002, 11:38 PM
  #3137
rcdougie's Avatar
Is the solid front diff something that you made or is a part you can buy? Ive been looking around for a solid front diff since I see the tc3's having success with it.
rcdougie is offline
Old 10-10-2002, 02:25 AM
  #3138
Lonestar's Avatar
Trader Rating: 14 (100%+)
Default Er....
Originally posted by IMPACTPLAYR
Dan- here's the beauty of Schumacher tourers.... since the suspension geometry has been unchanged from the first car you can start with a suitable Mission set-up and should be very close.
Sorry, was that actually destined to me too? it looks that it applies to my Axis 1 too. So the geometry hasn't changed? same A-arms, bulheads, knuckles? Funny, I have two sets of bulkheads, one that has lower camber links for more camber intake, I know this was supposed to come from a previous car (SST99 I think) and be the hot setup back in the days...
Thanks,
Paul
Lonestar is offline
Old 10-10-2002, 11:59 AM
  #3139
dougie, no it isn't a part that is available. It needs making. There are many ways of doing it. Personally i have drilled right through the outdrives and screwed them together. I am told that if you take the balls out and put 2 layers of card in, that works - but i don't know. The crude way is just to glue it all together!!
MattW is offline
Old 10-10-2002, 01:13 PM
  #3140
Racer X's Avatar
Cornerspeed: Hey, where was my invite? Email me, I have info you can use.
James: Probably SW, but there are some things that I need to get done this weekend and I'm not sure that I will be able to make it (if I can, I will). I would love to see the part.
Racer X is offline
Old 10-10-2002, 01:20 PM
  #3141
minicooper's Avatar
Originally posted by MattW
dougie, no it isn't a part that is available. It needs making. I am told that if you take the balls out and put 2 layers of card in, that works - but i don't know. The crude way is just to glue it all together!!
I took the balls out and put card stock on each side and tightened it up until the diff did not slip. A front solid axle is supposed to make you understeer but I get no more understeer than I normally due with my regular setup. Of course my problem is that I normally come in too fast for my turns (I need to learn to let go of the throttle )
minicooper is offline
Old 10-10-2002, 10:08 PM
  #3142
anyone wanna buy a mission? used only 3 sats and comes with spur adaptor. 200 obo
teamAE is offline
Old 10-11-2002, 04:31 PM
  #3143
Kevin K's Avatar
Trader Rating: 32 (100%+)
I have my spool built just like minicooper said but I left the balls in the gear I did not want to run the risk of it not being the correct width, as the balls rest on the rings and if you remove the balls the outdrives will be that much shorter. When I run mine which is most of the time I never wear out the blades like others are having trouble with. I also run the plastic bones as they bend and are cheaper to replace then metal ones b/c you will bend or break them with the spool in the car when you hit stuff.
Kevin K is offline
Old 10-11-2002, 04:40 PM
  #3144
Default Speedworld
Anyone racing Speedworld tommorow, what time does the gate open?
Mr. G is offline
Old 10-11-2002, 06:08 PM
  #3145
I will be racing Speedworld tomorrow. The gates open at 8:30 and the racing starts at 11:30. See you there.
James Nguyen is offline
Old 10-11-2002, 06:09 PM
  #3146
Racer X's Avatar
Mr G: I hope to be there...they open at 8 I believe (the website hasn't been updated since they just started racing at 11 insteat of 6)
Racer X is offline
Old 10-11-2002, 06:14 PM
  #3147
Racer X's Avatar
What James said...
Racer X is offline
Old 10-11-2002, 07:11 PM
  #3148
Pit-racer's Avatar
I read somewhere that on our missions to use assoc. springs.Which ones are the general to use?
Pit-racer is offline
Old 10-11-2002, 07:46 PM
  #3149
fireblade's Avatar
James likes Shumacher, I like associated. Shumacher, when they paint them the paint is not sanded off so it makes the bottom and top of the spring unstable. Both are good, I just consider myself lazy and run associated.
fireblade is offline
Old 10-11-2002, 08:59 PM
  #3150
BigDogRacing's Avatar
Trader Rating: 12 (100%+)
All who run AE springs: Do you guys just flip the adjusting nut over on the threaded shock to get the adjustment down far enough? I know the red Schuie spring is 20lb and the blue AE is 17, but they feel the same to me. The red AE (22lb) feels stiffer than the red Schuie. I suppose it doesn't matter except on the track, but I was just curious if anyone noticed this.
Oh, one last question: are any of your Schuie springs shorter than others? My red are like one coil shorter than the blues and greys... just curious
BigDogRacing is offline
