Schumacher Corner
How do you measure droop from chassis to floor?
measure the ride height, then lift the car up at the end your measuring and just as the tyres come off the ground measure again
subtract the 2 numbers and thats droop
Sup boys & girls! Just stoppin by to see whats up!
Seaball keepin the man love strong in here....
So you would have to check your droop every run as your tires would change in size when they get worn? Seems like an inaccurate way to do it
Super Moderator
I run rubber tires and still set my droop by subtracting the two numbers.
Super Moderator
Super Moderator
and yes i did noticed the lower steering set up
I just ordered my Losi Type R this weekend and was thinking of buying the SpeedPassion ESC. Now I am not a what ever is the hottest thing going this weekend type purchaser. I went to my track and was told I would be better off getting an LRP and was also told none of the TOP drivers for the Reedy Race ran the SP esc so can someone give me the good, bad or indifferent on this esc. Why you think it would be or would not be a good purchase. I will be running stock since I am a novice. Thanks in advance.
those are x ray springs from the new batch I think they were 30's they are marked with a # i think
Super Moderator
Hello
i´m writing because i´ve got a problem with drive shafts of MI-3
i know everybody says that the silver ones (u3020) are better than purple one, for me are just the same (broke as glass)and that´s my only complain about the car.
i´m going to put the steel ones (U2151) but a guy told that i have to put a spacer.
anyone of you are using the steel drive shafts and how you tighten the hex´s against the Hub ball bearing, cause i want to wear that ones but i don´t know what kind of spacer do i have to use.
please help me in this issue
Joao Martinho
Joao Martinho
R/C Tech Elite Member
Try U3267's for CVD's
Hello
Joao Martinho
Joao Martinho
