Schumacher Corner
looks interesting but a bit confusing
R/C Tech Elite Member
If you ran "my" LiPo you wouldn't have that issue!!!!
Our track is med high and tight track (carpet)...I was (am still) using the Jonas Viskafors Carpet Rubber Setup.......it said it is for MOD motor, but actually was very nice and easy to drive on 13.5 or 10.5 as well. I was not aware of that setup untill the fellow Mi3 driver used it and made some low 11s lapper....and I have been using it and do little adjustment to fit my driving...give that a try.
P.S....the only adjustment you have to do since you are running LIPO (like me)...the Center Track Rod, you have to use the 2nd hole from the FRONT and use the short carbon steering plate in order to give clearence of your LIPO. Or the steering plate's bottom screw/space will rub against your lipo while turning...I used the above setting and it still drives good. I've adjust the front (softer) and generate more steering.
http://www.racing-cars.com/usa/image...skafors_07.pdf
So I received 2 pretty good questions I said I would address on here...
1. How do I mount "MY" LiPo?
2. How do I have "MY" GT mounted?
Insert pics below
I use a custom PVC LiPo tray made by a local friend and a PPD EZ LiPo battery tray weight under it to keep legal weight
My electronics are normal, but I do have my spektrum receiver hiding behind my speedo, but between my belt and the controller.
Insert pics below
Adam - dude - call Goetz and have him give you the hook up on Black Dye if you are going to run that thing!!
Thats the first prototype, they're being made in black now...
That needs some green dye
Green and purple? Are you intentionally trying to build the ugliest touring car in existence?
Super Moderator
Trader Rating: 32 (100%+)
Adam....will you guys be getting these in stock anytime soon????
http://www.redrc.net/2008/04/speed-p...mat/#more-8662
Super Moderator
Thats being looked at closely Kevin.
