Schumacher Corner
#2522
KingG: No you can't since the nut would interfere with the steering arms. The part must be threaded which is why the Fireblade part is used. The end result is matching the front and rear hingepin heights
Pit-racer: I'll get that out to you and Randy...I really hope tomorrow. Summer is supposed to be the slow time, but the last three days have said different at work. Tomorrow...
#2523
I think the point was to use the other rear hinge pin mount. The one with two screws. I think it will do if the height is shaved down slightly. I made some custom mounts out of aluminum. I can post some pics after I've anodized them.
#2524
yeah sorry for teh confusion, this is what I meant...the hingepin mounts for the rear of the car....perhaps the ones which can be flipped for rear inboard toe. possibly need shvaing down as JesseT has said
#2525
jesseT....You have to remove to much material away from the rear blocks for the bellcranks to clear. That is the way we did the first prototypes and we found the alloy blocks to work much better, plus you can flip the alloy block over and run the stock roll-center.
BTW, the new Warpspeed Chassis (3mm) is in stock now and we are also taking orders for the 2mm chassis due to arrive in 2 weeks time.
#2526
Hey Paul or Racer X, I have 2 different part no's here for the fireblade hingepin mounts, could you please tell me which part to get in:
u1988: O deg pivot
u1989: 3 deg pivot
Cheers
u1988: O deg pivot
u1989: 3 deg pivot
Cheers
#2527
Trader Rating: 32 (100%+)
King G......you need both part numbers for the mod. The 3 deg blocks go in the front and the 0 deg blocks in the rear.
#2528
King G, we've just used the 3 deg block in the UK.
#2530
Those who have requested my Mission setup, please send an email to [email protected] and I can send it back as an attachment.
#2533
Mission Upper Wishbones
Has anyone been having problems breaking upper wishbones? My son and I seem to be breaking upper arms everyweek. Does anyone make any after market upper arms?
Thanks Jack
Thanks Jack
#2534
yesterday testing indoors I broke an upper left rear arm, wasnt a fault of the cars, as I brushed a pipe exiting a hairpin, the PVC pipe has a metal joint which loves wheel nuts!...it grabbed the nut and tore the wheel rearward.
I was well pleased to see that the upper arm was the only casualty..The schumacher cars are very durable, very well engineered, and very few spares are required....
I have found that the upper arms, and a pair of front and rear lowers are all thats I have needed.
#2535
Re: Mission Upper Wishbones
Hope this helps!!!
