Schumacher Corner
R/C Tech Elite Member
I was thinking of using the SPGT and the 2.5 around a 5.0 FDR and see what kind of speeds I can get
By the way the Marcos, the SPGT is a pretty nice speedo, we ran a sensor based motor with and without the sensor wire. You could literally feel the difference but you could run it either way...I was impressed
Super Moderator
I told you two weeks dude, but I can promise you I'll have mine first, then take a pic and email it to you to make you jealous
hey guys, i'm at a away race this weekend and the track has a old box of shouie parts for missions and sst's anything you want me to look for?
or anything i should be looking for.
FYI, most 6 cell guys run a 4.5 and thats pretty insane. The 5 cells guys run 3.5's and go faster then the 6 cell guys.
I think you may have missed the sarcasm in that Adrian.
4.20
last year we ran the 13.5 in the 160 to 180 range @ my local track I run it 140 to 150..This is true U can over gear the motor and get nothing but heat same lap times and more motor heat ..rubber tire it's like 114/39 I will see what 4.20 range doe's soon as I dont have my 96 spurs yet..I will post what I find..
Ran that ratio and lap times dropped. I didn't temp but I know a good number of people running that around here. I'm pretty sure Trackside and The Track are bigger then Allens or where you run...not positive. I just gear up till it cannot fit :P j/k
yes Allens is much smaller than S and N's what gearing to do run? thanx
Super Moderator
Super Moderator
I'm leaving the 1:1 to Shawn
Anybody have a set-up for LoWWWWWW grip outdoor
Just had to deal with that last weekend. My quick answer, not yet. Last track I ran on was so low grip that no change I made to the suspension could be felt. We were pretty much drifting on the track. I'd get 1/4 the way down the straight at 1/2 throttle and the tires would light up.
