Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 10-11-2007, 05:20 AM
  #22186
Skiddins's Avatar
Originally Posted by justin lessard
Im not old enough to drink beer for 5 more years..but I'll chug a juicebox and break it down..LOL
Oh well, you'll have to doa big European race in 3 years, I think you might be legal now in Italy!
Skiddins
Skiddins is offline
Old 10-11-2007, 05:28 AM
  #22187
dude doesnt germany have a no drinking age?
come to aus when yr 18 thats our age limit lol i turned 18 in july thank god havnt found my choice of poison yet i tried corona and a few aussie beers but the dont do it for me the clossest ive come to liking a drink is southern comfort and thats a pretty sweet drink so its soft
aus jd 2703 is offline
Old 10-11-2007, 05:51 AM
  #22188
KyLayfield's Avatar
Trader Rating: 86 (99%+)
Originally Posted by jimmy..maddison
my vegas set up is now on the scumacher website
thanks jimmy
Jimmy- Am I reading your setup correctly? It says you used 5 cells? Was that in 19T and Stock?
KyLayfield is offline
Old 10-11-2007, 06:12 AM
  #22189
redlion's Avatar
Trader Rating: 12 (100%+)
Originally Posted by Big Features
Maybe I over simplfied what I was trying to say, I was trying not to get to technical. The angle of your shocks directly reflects how quickly wieght is transfered. Example: Standing the rear shocks all the way up on the towers with make the rear of the car react quickly to steering inputs. This will cause the car to rotate quicker and provide more initial steering. Laying the rear shocks inward will slow the reaction and make that end of the car feel lazy, and follow the front end less agressivley.
Because the car isnt so reactive, and is suspension rate is softer to car "Feels" like it has more grip
That makes it to simple. Back to the drawing board.
Wes
redlion is offline
Old 10-11-2007, 06:49 AM
  #22190
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
mmmmm Oktoberfest!!!!
abailey21 is offline
Old 10-11-2007, 08:59 AM
  #22191
JayBee's Avatar
Trader Rating: 31 (100%+)
With all the iiC rubber set-ups being posted, I haven't seen any hint of the tire choice. Or was there a spec rubber tire used?
JayBee is offline
Old 10-11-2007, 09:03 AM
  #22192
abailey21's Avatar
I think it was spec
Old 10-11-2007, 09:11 AM
  #22193
theisgroup's Avatar
jaco green
theisgroup is offline
Old 10-11-2007, 09:13 AM
  #22194
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Must be an error, he was running 6.
Randy Caster is offline
Old 10-11-2007, 09:16 AM
  #22195
Originally Posted by abailey21
A wall, hard, very hard.
If your car has that much tweak it could be a bent bulkhead.
Before I put a car on the track I check it to make sure it's perfectly flat on the chassis, droop is perfect, and tweak is perfect. Knowing what your car is going to do on the first lap is sometimes hard, but knowing your car is set perfectly will definately help your confidence going into the first turn.
Old 10-11-2007, 09:18 AM
  #22196
JayBee's Avatar
So the new Jaco Rubberz (green) were the spec.....interesting
JayBee is offline
Old 10-11-2007, 10:50 AM
  #22197
DIALED's Avatar
Trader Rating: 96 (100%+)
On the tweak issue--
I've found that the lower deck can tweak between the four screws for each bulkhead. Just loosen each of the four (w/o load on the chassis) and re-tighten. The shock towers can do the same. With the chassis on blocks, loosen both screws and re-tighten, making sure the shock mounts are equidistant from the set up board (use calipers).
DIALED is offline
Old 10-11-2007, 10:59 AM
  #22198
JayBee's Avatar
'bout time
JayBee is offline
Old 10-11-2007, 12:38 PM
  #22199
Customworksking's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Nexus
Custom.
You coming this Sat. to the Hurricane Allstar Carpet race? Just wondering. There should be a handful of peeps running Mi2 ECs and/or Mi3s.
I want to come but the guy I was going to ride with backed out so, I will know later if my GF has to work Sat so we can come up!
Customworksking is offline
Old 10-11-2007, 08:35 PM
  #22200
skypilot's Avatar
Trader Rating: 14 (100%+)
where do the jaco tires for vegas fall within the sorex/rp lines. 30's, 32's??
thanks.
and is there anywhere i can find a choice of Mi3 avatars without stealing one from you guys?
skypilot is offline
