Schumacher Corner
Super Moderator
hey,
i recently bought an mi3 (online), but dont have it yet.
i'm wondering if there are any precations are tips to make it better?
i know to leave those rings off the pulley's.
What foams are you carpet munch'rs running? 2xPink-Orange/2xPurple or 2xPink-Orange/Pink?
R/C Tech Elite Member
2X Pinks F/R
Tech Legend
Trader Rating: 51 (100%+)
Team Schumacher laid it down today at the ROAR Region 2 onroad today. 3 of the 4 Team drivers where in the A in stock touring and Steve Walters the loan privateer all made the show. Team Drivers Tim Getchell finished 2, I was third and Mike Kling was 5th and I think Steve was 8th.
We all worked together to help get the best setups for each of us in this brutally hot and humid summer day.
It was a great day as are MI3's all worked great.
Ran th new alloy driveshafts today and they worked great.; Very nice.
If you are into crashing (like me), get a spare upper deck. I think I've gone through 3 of them by now. Other than that, the usual, front and rear lower arms, maybe C-hubs... I have actually broken only one front arm besides the top decks, so in my experience the top deck is the weakest link
hi guys
I just rebuilt my mi3s rear diff but after a Lap diff screw getting loose almost come out off from diff...
does any of you have any idea what cause of that screw getting loose
thanx in advanced
thanx in advanced
did you lock it with the set-screw?
does anyone use trakpower lipo's in the mi3?
Alright fellow Schuie drivers - i need some help. I have my car pretty much strapped when it comes to stock. It has great entry, mid, and exit cornering.
It has been one of my favorite cars to drive - EVER!!!
I am now starting to do some testing for 19T - and I still have my mid corner and exit speed - but upon entry - my car is pushing. I thought I might be overdriving it a bit - but even when I feel like I am not overdriving it - it just doesn't enter the corners like I would like.
I don't use a sway bar with stock, but it really settled my front end down with 19T. W/O the sway bar in 19T - my car digs in at the apex and kills my corner speed.
So here is my setup I landed on yesterday - but its still not there - any and all help would be much appreciated....
Anyone know in Chris Goetz Carpet Nats set-up, if he was using the lowered shock towers? It doesn't seem like it but I have 'em on my car and wanted to know if having them on will affect the set-up?
If you put up your stock tower to the lowered tower - you will see you have some of the same shock holes, but not all - it will change your shock angles and lengths, you will also need to shorten your shocks to make ride height
Thanks Marc
You have a lot of stagger in the springs, I'd think you'd want to run around a 30lb rear spring with the 35lb front, same with the shock oil, 50/30 is a big gap there too. Slightly lower front ride height than the rear. Stand the front shocks up a hole. I like running a little anti-dive to get the car turning in a bit harder.. Theres lots more you can do, but give a few of those ideas a shot.
McGoo...Try the front anti-dive Take a little arm-sweep out of the front.
What's the reason behind running the front shocks in the inner hole for foams and then using a much stiffer spring/oil?
Have you tried something similar with rubber tyres?
Cheers
Jonny
