Schumacher Corner
Originally Posted by Fred Perkins
This secret
Super Moderator
Originally Posted by StephenSobottka
So...what is the trick to getting this dang nabbed servo saver spring on?!
It looked like the mi3 moved right back up after it got knocked down. It was impersive to see how easely the cars got around the track they seam to run alittle to tight. compaired to the other cars. I thank when the drivers get use to driving the big races I will see it win.
were the schuie guys running the 5 cell batteries forward or back at the reedy race?
did the receiver get mounted on the same side as the battery?
Originally Posted by dawgmeat
well today is Monday
Originally Posted by AdrianM
They ran the new 5 cell chassis. This chassis has a pad to mount the rx behind the cells.
Super Moderator
Super Moderator
The 5 cell chassis puts the batteries in between the forward and back stock positions (just a little forward of middle) and moves the pack out 4mm to balance the car perfectly.
Would that be equivalent to putting the batteries forward and running the receiver toward the back behind the batteries if we were to run the 6 cell chassis?
Does it have a spot to mount the antenna toward the back as well? Glad to hear this is coming out because balancing the chassis is important.
Super Moderator
The chassis will be here in about 2 weeks. There is an antenna mouting hole right behind the RX
Originally Posted by Marcos.J
cool put me down for one
