Schumacher Corner
#1876
Hmmmm....I haven't had the problems you're describing...I run my shock only in the outer hole on the arm though...I've run them in every hole on the shock towers, and haven't had any problems setting the ride height there...Adrian from Schumacher USA or Racer X, or a few other guys will probably have a much better answer for you...
Ron
Ron
#1877
I forgot to mention, It's just the rear that won't go lower than 7mm. The fronts seem fine at 5mm. All shocks are the same length. using inner hole on the arm. please help!
#1878
Regional Moderator
Tick: thats odd that you cant get the car where you want it with the ride hieght. I run my shocks with the lower mount on the inner hole. On the shock tower, I have the front in the number two hole and the rear in the number three hole. With this setup, my car sits at a perfect 4mm front and rear. If I remember correctly, I built my shocks to 64mm from the top of the shock, to the bottom of the ball end.
#1879
Darseid: This is driving me nuts. I have all ball cups screwed all the way into the shafts and all shocks are the same length. I have the fronts at position 2 and the inner hole on the arm which sits the front a 5mm. The rears are also at at position 2 with inner hole on the arm and it sits at 7mm. I've tried all the shock tower positions and as expected, it did'nt make a difference. This is with the stock tires.
The shocks hold the springs with no slack. What the heck is going on!!!
#1880
Regional Moderator
Tick: I'm at a loss then. I also measured mine with the stock tires on. When I mount up my LP H13s or my LP Losi Yellows(both of which are REALLY low profile), then I will probably have to raise the ride height slightly. Other than that, the ride height is perfect.
If you have your droop screws set to have the arms level(like the manual suggest), I don't even see how its posible to get a 7mm ride height in the rear.
#1881
Darkseid,
I could bring down the ride height to 5mm by turning the droop screws almost all the way through. The problem is that this really compresses the shocks and makes it super stiff. AAAARGH!
I really appreciate your help though!
#1882
Regional Moderator
Tick: Again, thats very odd, the droop screws need to be turn in very deep to get the arms level, but on my car in doesn't even compress the springs at all. In fact, my grey rear springs don't even have tension on them until I set my car down. Otherwise they still have a little play in them between the spring retainers on the shock. The same for my blue springs up front.
Man, I can see why your frustated. I'm out of ideas. Maybe Adrian can help you.
#1883
The Tick. Do you have your shock over filled in the rear. This will cause the shock to add a little extra ride hight.
#1884
All my springs have slight tension in the shock with no play. The car hardly droops when i set it down. The oil level is fine. I'm still tinkering with it guys. Fortunately, I was still hooked up last night at the races. Thanks Again!
#1885
OK, I've practically reassembled the whole rear end with no dice. I think my only resort at this time is to put some spacers above the diff mounts which will raise the shock tower.
#1886
The Tick,
You may want to call Schumacher USA before you do that. The guys really know there stuff and are glad to help (813) 889-9691
#1887
Thanks for the number Damon! it's busy right now, but I'll keep trying.
I noticed that the softer springs are taller. The reds fit perfect with no slack, but the grey and blues are in ther pretty snug. is this normal?
#1888
It seems I can get the car to sit at 4.5 - 5mm if I use red springs only. Any softer spring is taller which makes the car sit higher.
#1889
Trader Rating: 32 (100%+)
Tick.....How long are your shocks??? The over all length should be about 66 to 67 mm long. Also make sure that you have the correct Shock tower on the rear of the car, there is a differance between the two. If you still cant get the springs to fit correctly you can run Associated springs or Losi springs on the shocks. I personaly like the Losi springs but they both work just as good.
#1890
Thanks for the tip Kevin. I realized that there is probably nothing wrong with my car. I looked at one of the setup sheets in the manual that used grey springs with ride height at 6mm in front and 6.5mm in the rear. I copied the exact same setup and also got 6-6.5. I gues the car is designed to ride high when you use the taller softer springs. I prefer to ride a 5mm or less, so I guess I'll have to find some shorter springs. I'm kinda bummed about that because I just bought a full set.
I'm not sure how long my shocks are, but I screwed the ball cups all the way in. Thanks for all the help guys!
