Schumacher Corner
Originally Posted by mo
Got the first run on the Mi3 today. Only got 1 practice run due to some electrical problems so I was testing every run. By the end of the day the car was really good. Got off to a shakey start in the main so I had to fight through traffic. Was in 2nd, chasing down the leader when I hit a corner pretty hard and jarred my battery loose so I had to pull it off. At least I had the fastest lap of the race.
I actually got to build a production kit today and found a few things that differ slightly from my preproduction. After talking with Mo he said my setup was a little on the lazy side for tight tracks.
If you need more steering from my setup try moving the ball-stud to the forward hole on the steering block. I didn't realize, but I've been running the optional steering track-rod (shorter one) and that allowed me to run the back hole on the steering block
Another change for tighter tracks is you can shorten the rear camberlink for quicker response. I used a longer rear link for my setup because of the open layout. You can also lower the front r/c or raise the rear for more steering.
It's nice to finally get some more drivers running the car as this will speed up the setup process
Less than 2 weeks
Less than 2 weeks
Originally Posted by dawgmeat
does thos apply to rubber carpet on a tigth track camber and going 1 hole up on the steering block
car
so how did u guy's get your car's from the UK?
Has anyone posted the bearings & turnbuckle sizes/count yet for the MI3? If not could someone please do? What about the complete diff part#? Is there a P-Dub bumper for the car yet?
When I last talked to PW he said they will have P-dub bumpers coming soon.
I'm not sure about a complete diff assembly part number.
bearing sizes:
10x15x4mm - x4
5x10x4mm - x8
5x8x2.5mm - x3 (2 of these are for the steering bellcrank, 1 is for the layshaft pulley)
5x9x3mm - x1
turnbuckle sizes:
35mm - x4
39mm - x2
24mm - x1
Happy?
bearing sizes:
10x15x4mm - x4
5x10x4mm - x8
5x9x3mm - x1
turnbuckle sizes:
35mm - x4
39mm - x2
24mm - x1
Happy?
Tech Legend
Trader Rating: 51 (100%+)
One day on the car and lots of good info coming in. I'm already trying to take it all in and started to wrinte stuff down already so I'm even more preppared for my new ride when it arrives.
U3223 is the part number for the diff.
bearing sizes:
10x15x4mm - x4
5x10x4mm - x8
5x9x3mm - x1
turnbuckle sizes:
35mm - x4
39mm - x2
24mm - x1
Happy?
bearing sizes:
10x15x4mm - x4
5x10x4mm - x8
5x9x3mm - x1
turnbuckle sizes:
35mm - x4
39mm - x2
24mm - x1
Happy?
Regional Moderator
So what do you guys think of the kit bumper. Will a P-dub even be neccesary?
Originally Posted by JayBee
I'm very happy buddy thanks You headin' up to Peel-It today?
