Schumacher Corner
#1741
Another Update on my Axis2...
Well guys, I went and raced at SRS in Scottsdale again tonight...Got there late, and was unable to run ANY practice packs...with the Stratus body, it had a bit more steering going into the sweeper at the end of the straightaway, but still seemed to push a bit in the infield, and was fairly easy to get loose at the same...I went back to the pits after the first heat, and moved both front and rear upper A-Arm mount into the upper position...they were both in the lower mount, per Adrian's setup sheet...WHOA...what a difference...the car has tons of high and low speed steering, and there was only one spot on the track where it started to get a little loose...I LIKE IT!! This was what I was looking for!! I wouldn't have guessed that moving that pivot point up would have made THAT mch of a difference...Anyone know why it reacted to the changes the way it did??
If I can get my head out of my butt, and get some serious practice in next friday, I think I'll be pretty competitive... I'm the only Schumacher now...My buddy defected to Losi tonight!
Ron
Ron
#1742
setup
AZ Ron what kind of setup are you using? I got a setup from one of the factory guys over here and I am still strugling with the setup.
Florida Ron
Florida Ron
#1743
My Current Setup
Here's the setup I'm at right now...
This is for a medium grip Asphalt track sprayed with Soda...I'd like just a LITTLE more rear traction without losing any steering...any suggestions?
Front:
Shock tower-3
Upper Hub Ball-1
Steering arm-1
Upper a-arm mount-1
Lower suspension arm-1
Hinge pin mount-2 deg
Oil-60wt
Spring-Blue
Piston-2 holes on Vari piston
Spacer-none
Length-66mm
Droop-2.5mm
Anti-Roll Bar-None
Castor-10 deg, one spacer in front and behind the upper a-arm mount
Toe in-.5 Deg Toe-Out
Ride Height-5.0mm
Camber-0 deg
Lower wishbones-stock, rear position
Driveshafts-Metal Universals
Rear:
Shock tower-1
Upper Hub Ball-1
Upper a-arm mount-1
Oil-60wt
Spring-Blue
Spacer-none
Length-66mm
Droop-2.5mm
Anti-Roll Bar-None
Anti-squat-none, blocks flat on chassis
Toe in-2.5 deg
Ride Height-5.0mm
Camber-1.5 deg
Lower wishbones-stock, mid position
Driveshafts-stock, plastic CVD type
Motor-Green Machine 3 (25/86)
Drive Pulley-15T
Body- Opel Vectra (I think!)
One Way-None
Front Tires-Sorex 32
Rear Tires-Sorex 32
Inserts-Sorex Medium A's
Tire Traction-Paragon Ground Effects
This setup REALLY came around from the original setup when I moved the upper Hinge Pin mounts to hold #1 from hole #2.
Ron
Front:
Shock tower-3
Upper Hub Ball-1
Steering arm-1
Upper a-arm mount-1
Oil-60wt
Spring-Blue
Spacer-none
Length-66mm
Droop-2.5mm
Anti-Roll Bar-None
Ride Height-5.0mm
Camber-0 deg
Rear:
Shock tower-1
Upper Hub Ball-1
Upper a-arm mount-1
Oil-60wt
Spring-Blue
Spacer-none
Length-66mm
Droop-2.5mm
Anti-Roll Bar-None
Toe in-2.5 deg
Ride Height-5.0mm
Camber-1.5 deg
Drive Pulley-15T
One Way-None
Rear Tires-Sorex 32
Ron
#1744
setup
I did a liile digging and found a couple of setups you probably found the one ones at schumacher. I also called a got a setup but I am still struggling with it. I know most of it is my driving and not knowing what to look for. How do you like that hudy setup board I am shopping around for one mabe that will help me get a little closer to being dialed in.
#1745
Oops...
I should have deleted the reference to the Hudy deal in that posting...I just edited it...I'm using an Associated Ride Height Guage, and the Integy Setup Station...the Integy deal is very nice...only thing that suck is you have to by the metric wheel nuts in order to use the caster indicators...with the Axis 2, Caster is either 7.5, 10, or 12.5 I believe, so you don't really need the caster indicators...I've been using the regular Axis2 wheelnuts.
Ron
Ron
#1746
setup
Is that with the laser?
#1748
setup
Sorex 32 tires you use is that for concrete? I have not tried any that high yet
#1749
Regional Moderator
Hey guys, I was going to be picking up a Mission pretty soon. I was wondering do you guys know what the part number is to the Posi-screw driver that Schumacher sells. I couldn't find it on their website.
I've been running Schumacher ever since their first TC and never bothered to get the right screw driver. So I figured I would go ahead and do it now.
Thanks for any help you can give.
#1750
RC Raptor...We run an Asphalt track, sprayed with cheap soda from the local Grocery store...28's were used when it was cool out...now we're into the upper 70's and 80's, so 32's are it...Apparently after it hits 100 degrees here, we'll be running 36's...
DarkSeide...here are two numbers I found for the PosiDriver...
U1261I Pozi Screw Driver No 1
W31310 Wiha pozidrive screwdriver
Ron
Ron
#1752
Pozi
I picked up a #1 carbide Pozi bit from www.wihatools.com
They also sell regular steel pozi bits and scewdrivers.
The carbide bit has been working great. Much better
bite than the smaller wiha screwdriver.
- Ben
- Ben
#1753
Anyone running a P2K2? Mine gets pretty hot at 24/86....anyone have any better luck with another ratio?
#1754
_neas_
Are you running the 17 or the 20t pulley? Is your track open or tight?
