Motor questions
Old 03-15-2004, 09:53 AM
Beeb's Avatar
Default Motor questions
I have the binary2 stock motor, which has the capacitors already on it and was wondering if I need to add a schottky diode still? Also, what about the Novak schottky diode motor module? Is that something worth getting?
Beeb is offline
Old 03-15-2004, 09:56 AM
CRASH's Avatar
Trader Rating: 26 (100%+)
Yes definetly add either the schottky diode or the Novak schottky diode. Either one will make a big difference. Just be sure to install it directly on the motor, not in line or attached to the speed control.
Later,
CRASH is offline
Old 03-15-2004, 09:58 AM
Default Re: Motor questions
just get the novak motor module it attaches to the motor and is designed for the new hott motors like the binary's that takes the place of the diod on the motor .. it is worth it..
mb racer is offline
Old 03-15-2004, 10:38 AM
PitCrew's Avatar
uh, why not? Since electricity travels at roughly 10% the speed of light(186,000 miles per SECOND) through conductive material, the time it takes to travel the couple of inches is in better words 0 as in instant. Also, the resistance of the wire in this speedo/motor circuit is negligable. therefore, there is no real difference is you attach the diode at the motor or had 4 inches of wire between the motor and diode. It does the same thing.
PitCrew is offline
Old 03-15-2004, 10:41 AM
pro3racer's Avatar
get the shotockly(sp) diode, done deal. I also run a B2, and the change in temp, and overall smoothness is amazing.
pro3racer is offline
Old 03-15-2004, 10:47 AM
Beeb's Avatar
I have the schottky diode from my LRP ESC, but I was just wondering since I've been out of RC for awhile and motors didn't come with those pc boards attached to them back then. I wasn't sure if they minaturized the s.diode and started putting them on the motors or if it was just the capacitors.
I remember having to put 2 caps and 1 diode on, and when I saw the motor with 3 caps on it I wasn't too sure.
Beeb is offline
Old 03-15-2004, 02:00 PM
pro3racer's Avatar
that little board is just the capacitors, you still should put the diode on.
Old 03-15-2004, 02:34 PM
edseb's Avatar
Yeah, and make sure you gear down a couple teeth on your binary. The way they work, you need to, and the perforamance will still be a bout the same.
edseb is offline
Old 03-15-2004, 02:53 PM
jeepnyy's Avatar
Is the shotckey diode needed for Keyence V Zero Extreme 4 cell oval high-bank track for B2 ?
jeepnyy is offline
Old 03-15-2004, 04:09 PM
CRASH's Avatar
Just repeating info I was given by Chuck from Novak, thats all. i figure if he says this is the way to do it then it must be.
Later,
CRASH is offline
Old 03-15-2004, 07:05 PM
Brandon R's Avatar
i got a new gt7 and its got a little box thing that im told is a very powerful diode so there is no need to install another so if you got one of those new gt7's with the box in the wire dont worry about installing a diode!
Brandon R is offline
Old 03-15-2004, 08:10 PM
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
Do NOT run a diode. The keyence is weird. One of the local team guys blew a couple up running them, dunno why. Keyence actually states not to use one too, so go by the manufactures instructions.
-Sushi Boy
Korey Harbke is offline
Old 03-16-2004, 12:08 PM
PitCrew's Avatar
To heck with Chuck @ novak. he is telling you that so you will buy their WAY WAY overpriced shotcky diode (that you could get for $.50 from RS) and put on one EVERY motor you own. Marketing.
PitCrew is offline
Old 03-16-2004, 02:04 PM
Beeb's Avatar
That sounds about right.
Beeb is offline
Old 03-16-2004, 06:39 PM
Tek Nickal's Avatar
We're all consumers that buy over priced items, don't worry. Stores have to make atleast 20 - 30% of what they sell it for.
Tek Nickal is offline
