Motor questions
More like 50-200%
You wouldn't belive the markup on some regular items...
ottoman: Put one on for the RR, you will feel the difference, it's soo smooth. Second thing: If you know anything about the losi's, what is the difference in seteup from trackside to road rage? I'm thinking just to lay the shocks down more.
sounds like I should add them. if i wanted to buy them at raido shack, what is the part # or description of the diods? thanks!
#20
Set ups are about the same... depends on the traction and track layout...
#21
The main job of the diode is to protect the speedcontrol from getting damaged during braking. Thats why you can not use one on a speed control that has reverse it keeps the current flowing in one direction. With a touring car that doesnt use much brake its probably not as crucial compared to other classes that might require alot of braking.
#22
Originally posted by PitCrew
More like 50-200%
More like 50-200%
also while we are the motor subject what size is the motor bolt in screws 4-40?
#23
Originally posted by Brandon R
yeah you are right....i mean i have seen people selling body pins for like 1.25 a piece....i get 100 for under 3.00!!!
#24
#25
ottoman is right on the diode...ive tried with and without it and i didnt notice a difference with my sedan or Associated B4.....i never use brakes either...even in mod sedan....i do burp the brake on off-road however every once in awhile when i have to make that pass on the inside of a corner
#26
I get all of my small stuff like screws and pins and tubing from a place called small parts in florida. The have all of the screws to make a chassis all stainless if needed and can also to titanium or aluminum for little extra. smallparts.com and order a catalog its got ALOT of good stuff in it
