Sand blasting pipes?
i dont see y not
sand blasting,bead blasting or media blasting will leave the surface porous which will enable even more debris to stick to it.
if you really want to clean your pipes, get a deep fryer and some cheap anti-freeze (coolant) 1/4 fill the deep fryer set on a low heat and leave the pipe in there over night. The coolant is an aluminum conditioner and will clean it.
Make sure to do this in a well vented shed or outside as the fumes from the glycol may be dangerous(very dangerous apparently).
Sand blasting will make it easier for gunk to stick & get baked on like mentioned above but, it will also have the effect of increasing surface area by upto 100% & so cooling if a cool pipe is beneficial for you.
Use caustic soda, or any other outlet cleaner
hey guys, check out the Speed Shop thread in this forum. I offer a pipe clean service that will have it looking as fresh as possible for $10 plus shipping.
We have a lot of other neat services as well.
My direct email is [email protected]
Does anybody know how to harden a pipe?
