Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#1201
Paul,
I have heard great things about the TP motors and am thinking of getting one. When running 17.5 blinky I have heard the blue rotor can really help. What would you recommend if you were running 17.5 blinky at West Coast? I know silly you don't run that but I know you are familiar with the track.
Thanks.
Thanks.
#1202
Paul,
Thanks.
Thanks.
#1205
Trader Rating: 22 (100%+)
Hi Paul,
Just wondering if you could give me some tips on radio setup for 1/12.
Josh
Josh
#1207
The ass is smart in this one.
Maybe I should have sat on his shoulders?
#1208
Hey Paul,
In TC, rubber tire, on carpet, when would one consider changing from the std eccentrics to the 1mm eccentrics? What are you looking for when you do this change?
#1209
Paul, another question for you.
If you had a TC car that could only balance out by adding weight to the point that it far exceeded the minimum weight limit. Would you be be more tempted to ditch the weight and balance pin check and concentrate on getting the balance of the car via a tweak bar? (So you would have equal weight on the 4 wheels?)
#1211
Hi, Im Back from a long trip, sorry for the delay..
Looks like Jim got you the info you need already. 150deg would be nice, but dont worry to much if its a little warmer.
thanks!
Hi, I dont use the abs feature on the 4pks. it may not be easy on the esc but any kind of brake is hard on esc's. i doubt you would have esc faliures by using the abs function. But no i dont use it.
Thanks.
Thanks, it was fun running with you too. Glad that the car got better for you. i think it was hard for everyone last weekend. see ya!
Hi Josh. for me its pretty standard, I will set my epa's to turn about a 4 to 4.5 foot circle both ways. then i always use a good amount of negitive staaring expo, I will start with -30% steering expo. severyone likes their brakes different so set the brakes how you like them and thats about it.
Hope that is what you were looking for, Thanks.
Hi, normally i feel like the car has more traction with the higher diffs. i usually run +1 high all the way around. that being said i havent tested it properly in a while. when your at races and do these changes its hard to tell sometimes with the track changing so drasticly. so i could be wrong. Thanks
Hi. you should beable to have the best of both worlds by mooving components around.
I assume that you re talking about the battery side being light on your TC, I would not run it overweight. I would do away with your battery holders and start hanging the battery farther out side untill the car ballances out on the pins. The car will drive well this way and not be overweight. Good luck.
Paul,
Thanks.
Thanks.
thanks!
Thanks.
#1212
Unfortunately in this situation its the battery thats the heavy item. I thought about flipping belts and moving the battery inboard more but I don't think I would have good top deck clearance. If I get everything balanced out its usually at 1420+ range. Thanks for the input anyways.
#1213
#1214
Hi Paul what body are you using right now? Any tips for mounting your body?
#1215
Hi. for my electric TC the speed 6 light weight is still the norm for me, I dont dislike the LTCR or the P37 but i normally stick with the speed6.
I tend to mount mine a little bit forward, like 2mm forward of perfect center, i run the stock wing 10mm behind the rear bumper as always. so nothing has changed in a while for me.
for 12th scale i run the AMR12 lite, 10th nitro the P56, 8th scale i like the 909 best, Obviously all Protoform.
thanks!
