Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#467
I found this too and it totally describes Rap Snacks!
http://www.cultureblues.com/2010/04/...nd-rap-snacks/
#468
Hi Paul,
Can you describe your break-in method for your nitro engines?
#469
HI, I im really not the "nitro motor guy" atall. but when i get a brand new engine i idol 5 or 6 tanks threw it keeping the temp around 180 by adjusting the low end accordingly. It is Best to use a very high oil content fuel when doing this. ill shut the motor off after every tank and let it cool down completely between tanks (heat cycle's). after a handfull of tanks like this i will loosen up my 2 speed and tune the motor in on the track to run a good temp, 16%nitro 260deg , 20% 250, 25% 235, 30% 220. Ill run the motor like that for a good while, maybe 1 gallon. Then ill replace the rod and lean it out good and hope its fast.
Again i dont know for sure if that is a good way. but that is how i would do it. if im at a race and dont have the time to do that i would just idol the tanks with the heat cycles and let her rip, and of course prey. lol
#471
Congrats on your recent win at ROAR
I was just wondering how do you check for diff slip?is it
1) grab either tire and the spur with one hand and check for slip by
by turning the other tire with the other hand? if you do which side
do you check for slip.
2) grab both tires and check for slip by turning the spur gear?
thanks in advance
thanks in advance
#472
Hey Paul,
Dieter gave me your message you asked him to forward to me while we were checking out the off road Nat's. Right back at ya my friend!!!
#473
Thanks RAB. you too. it was a great race.
Thanks, you can do it both ways if you know what you are looking for. I always grab my LR tire and spur gear and try and slip the right side tire. for mod i always look for the belt to climb the gear and almost skip, but the diff will slip before the belt skipps. for stock classes (less powe) your diff dosen't have to be as tight. the more free feeling the better with no slip.
LOL
thanks in advance
thanks in advance
LOL
#474
Isn't 1420 grams a normal minimum weight? In what races do you run 1350?
What's a normal size tire -- Sorex? Was the vtech tire bigger than a Sorex?
Also on your T3 setup sheets since Reedy Race you haven't indicated the swaybar mounting point you use on the rear arm -- middle?
#475
Hi Paul,
Running a T3 on carpet with JACO blue tires, I have a pretty decent setup, but now we have gone back to a slower motor combo, again my car is pretty decent, BUT, it has the slightest corner exit over steer (sort of feels lazy and over rotates coming out of the corner). I was thinking rc change with rear upper link, or shock position change, but not feeling positive on either of these or which direction to adjust, what do you suggest.
Thanks much
Oh ya, Vegas baby.
Thanks much
Oh ya, Vegas baby.
#476
R/C Tech Elite Member
Hi Paul,
Thanks much
Oh ya, Vegas baby.
Thanks much
Oh ya, Vegas baby.
#477
Hey Paul, thanks for all the helpful information you give us on here.
"normal size tire" LOL I guess i could have used defferent words for that, the LRP tires are the largest tires that i have ever run.
The rear bar was mounted in the middle hole.
Hi Paul,
Thanks much
Oh ya, Vegas baby.
Thanks much
Oh ya, Vegas baby.
Ill see ya in a couple days!
#478
Paul, thank you so much for the help you gave Jason and me at the IIC. I was once again impressed by your knowledge and willingness to help others. I hope Xray and Mr. Hudy are aware of the fine job you do not only racing, but helping others at the events you attend. I cannot even count the number of times I saw you put aside your own car to look at and help others with their cars. It is hard for me to imagine how you are able to do this given the level of competition you are involved in at this kind of event. And to watch you compete, in person, wow.
Thanks again, Keith and Jason.
#479
Thanks again for your help at the IIC Paul. Both in Vegas and in Orlando you have helped make my week a more enjoyable experiance. All the drivers in the pits were talking about how you are the quintessential example of how a company representive should be at one of these events.
Cam
Cam
#480
Paul, I can only add to the 2 above posts, your passion for the sport and support for the products you use are second to none. Thanks for all the help in the past as well as Vegas, even after the race hanging with us was priceless. Hope to see you again sson.
