Ask Mike Blackstock
#106
tc3
Hey mike just curious as to what kind of roll out you would run in stock @ s&n track ,pinion and spur with tire would be great foam tire thanks.
#107
jwillman74w.. Yea i think it is hard to get a base setup going being so different than anyone else...
Lowline... Stock gearing.. Well this is a shot in the dark from where we run are 19 turns.. But i would say somewhere in the 32-36 range.. with a 100 tooth and 2.25 -2.28 tire....
Mike
Mike
#109
Brian McGreevy,
Please post your base stock setup anyways, I'd be interested in it.
#110
Ok here goes...this should work for almost all track conditions, depending on grip I just change the amount of time I let sauce sit...
Front:
50wt AE oil
Yellow Spring
#3 piston
Rear tower on front, middle hole
Outer hole on arm, will have to shave a little off c-hub so springs dont hit.
4 degrees caster (AE blocks), 6 degree if you want/need a little more high-speed turn-in
Losi steering knuckles
~2 degrees anti-dive, add .030" shims under the F block.
F-0
BRP .078 swaybar
Upper inner camber link
-1 camber (set so that tires wear flat, -1 has worked at the tracks i've raced at)
.045" shims under steering knuckle ball studs
Rear:
50 wt AE oil
Purple Spring
#2 piston
Outer hole on tower
Outer hole on arm
Losi rear 0 degree hubs, outer hole, run 1/2 degree backwards to get 1.5* toe when grip comes up
R and R+2-0 blocks
no sway bar
-1.5 camber, again set so tires wear flat
middle wheelbase
4 mm ride height
Parma Alfa body (Mazda works good too, but I prefer the Parma)
Purple Orange (Plaid)/ Purple tires, Dbl Pink Orange/ Dbl Pink if the grip is low. Sidewalls glued when grip is high. Usually around 2.25-2.28 for race diameter (Jaco/BSR).
When setting droop....
Unscrew droop screws a turn or two. Set ride height. Should have lots of uptravel after that. Then, lift the car off the ground, and screw in the droop screws till the springs just touch the shock collars. I never use the 'gauge', and have used mm over ride height much before, but this way was faster on the track...
For you TC3 guys, run the batts forward as you always should. I run for Warpspeed and the chassis has the batts centered between the forward and back slots of the TC3.
If you have any questions with the setup, feel free to ask.
Front:
50wt AE oil
Yellow Spring
#3 piston
F-0
BRP .078 swaybar
Rear:
50 wt AE oil
Purple Spring
#2 piston
Outer hole on tower
Outer hole on arm
R and R+2-0 blocks
no sway bar
middle wheelbase
4 mm ride height
#111
Trader Rating: 32 (100%+)
I have a question.....that setup looks a lot like the Brad Johnson setup that he ran at Snowbirds and gave to out to people.....hmmmm Is this set up one that you came up with all on your own???
#112
I'm looking for a carpet set up/suggestions to start with. I am running rubber tires (cs-22) and stock motors. I have tried the suggested starting set up as shown in the manual with no luck. The biggest problem I'm having is keeping the rear tires planted behind me. The rear seems very loose mid corner.
Any suggestions?
Any suggestions?
#114
ummm ok
#116
RC-Racer... Go here and try this setup.. I know it is a good starting point. Since i do not run rubber tires on carpet that much.. Atleast it will get you in the right direction...
http://www.rc10.com/racerhub/setup/r...lheim_2003.pdf
Mike
Mike
#119
rc-racer.. Yep that is it.. Just put it on there ....
tmunno... Yea we had a blast.. Wish there was more time.. But i was pretty tired. but we are going to make a annual thing each year...
Mike
Mike
