Lathe?
Lathe?
what is a good lathe to get on a budget and would you suggest getting a brush serrator.
hudy is one of the best when it comes to lathes but costs a bit more. cobra have good lathes but dont cost as much. i suggest getting one with v-guides instead of ball bearings. also, get a carbide bit rather than a diamond bit.
i use a brush serrator only to break in new brushes or clean (skim) old brushes. most of the time, i reuse my brushes even after cutting the comm. i think integy makes a great serrator that creates deeper serrations on the brush. if your budget allows, get a brush factory because it can also make custom brush cuts, aside from making serrations.
Why is a lathe with v-blocks preferred over a lathe with ball-bearings?
v blocks require almost no maintennance compared to ball bearings. when youre using the lathe, comm shavings sometimes find their way into the bearings and may cause binding or vibtration.
Once bearings gain slop you can replace them or even just fill then with jb weld and turn them into v-guides.
I just chuck the arm in a drill and use sandpaper........
Not really, I have a Trinity lathe, and it is capable of all I need it to be. Its case also holds 2 motors and 6 arms, and has bearings and v-blocks. A pretty good package for $150.
Matt
Matt
Are you suppose to use any oil on the comm itself while cutting it? If so what kind?
from my experience trinity's brush factory is a POS, get integy's new serrator instead
also hudy's lathe worth every penny you give up for it, it cost a little more initially, but it will last you thru your ep carrer
Cobra gets my vote for the best cheap lathe. And cutting fluid is needed when cutting comms. Itll work ok without it if your careful, but its alot better smoother cut with cutting fluid.
what kind of oil should I use for cutting fluid? Will any lightweight oil work or do I need some special stuff?
A thin oil will work better than nothing but there are special cutting fluids that will work better. You can get a small bottle at your LHS. Or you can go to a hardware store and buy a large bottle for about the same price.
put a drop of bearing oil on each contact point (v-guides or bearings) and spread it around a bit. dont use too much - if you turn on the lathe, the oil might splatter in your face when the armature spins i use a sharpie on the comm so it will be easier to see if im removing just enough material to make it round again. i used to put comm drops as a lubricant when i cut but it doesnt last that long.
