Improve handling in Xb8TQ
One of the local racers at my track has suggested I widen the wheel base on my car, to improve the handling on our track.
I forgot what part he advised I get to do this but suspect it was these?
Would these parts "Alu wheel axle offset +2mm" be the correct parts?
Is there anything else I need to buy at the same time?
Do these come with teh pin that goes through them?
.. Not sure if they come with the pins bit you just use the pins that your using now in your wheel hex
Thats what your after although with those your car will probably be a little slower in the handling dept,but will definatly be easier to drive and not get out of shape.
?? just order a set..
you should get the 38 teeth front conical gear too , drives a lot easier
try 3000/3000/5000 diff oils
