Serpent S120-Link
#451
Ok I built the car as per kit instructions, I currently have zero degrees toe, zero degrees camber, 800cst shock oil, I used a thin smear of diff grease on each tube, running 40 shore front and 30 shore rear ulti tyres. The front springs are kit and so is centre shock. I'm currently running 4mm ride height front and rear. I've installed a futaba mini servo for steering duties. I usually do a full application of tyre additive for the rears and only inner 1/3 for the fronts, both around 10 minutes before the race. I'm using an orca rx2 4.0 motor matched to an orca vx1 esc and orca 1s lipo to power it up. Weight balance is slightly bias to battery side. I think that's about it for my setup. My initial thoughts was to increase front ride height, no tyre treatment on the front, remove grease on damper tubes to lighter oil. Any thoughts would be greatly appreciated.
Regards, Andrew K
Regards, Andrew K
Ulti X-type tyres? X Medium rear, and X Hard front?
Rear additive 20 minutes, and front only 5 or even less, and only 1/4 of the inside of the tyres.
Fronts 41.5 - 42mm, rears 43.5 - 44mm
Side tubes, I would put 10.000 in, instead of some diff grease.....
#452
Thanks for the advice guys, will try a range of these suggestions at the track. I'm currently using XS (soft) rears and XM (medium) fronts. Was thinking of going to XH (hard) fronts. However I see that ulti have a J range designed for asphalt so I'll start all over again I think for tyres. I'm going to rebuild the whole car and double check everything for possible binding or anything of that nature. Also another question, do most people run 14 or 16 guage wire to the motor for better pod movement?
Regards, Andrew K
Regards, Andrew K
#453
I also tried the Ulti "Y" compound, a bit harder and less grip then "X".
I'm driving my S120, in 13.5T blinky, with Ulti XM rear, and XH fronts.
YM rear, and YH fronts where sliding to much, but XM rear, and YH fronts, might do the trick for you, don't know, haven't tried that combination yet.....
#454
Regards, Andrew K
Regards, Andrew K
Are you running on carpet ?
X-Hard Fr
X-Med Rr
#455
Thanks M7H I'll look into the Y compound fronts, could do the trick. Redbull the track is asphalt with a boral painted surface which increases traction. It's in between low to medium traction if that makes sense.
#457
Tyre wear is actually really good, over the 8 minutes it's minimal and I'm getting even wear on each corner so I think that's a good sign of a balanced car?? I'm going to try stiffer front springs and loosening up the rear. Following that will increase front ride height. Thanks again guys.
Regards, Andrew K
Regards, Andrew K
#458
S120 L to LT conversion
I have an assembled but never run S120L and am looking into upgrading the kit to LT spec with SER411259 Damper Tube Set $40 & SER411263 LT Upgrade kit $100. Are there any other parts I'll need to complete the upgrade from S120L to LT? Is the S120 LTX enough better that I'd be better off spending another $140 and getting that?
#459
#460
Hi guys,
would anybody mind telling me the length (between hole centres) of the sidelink please?
Also, does it have a standard size ball fitment? I am hoping to fit the links to associated pivot balls, and to an X-ray car!
Regards,
Cyclone
Regards,
Cyclone
#461
the serpent link is interchangeable with the AE R5 link. (personally I prefer the combination of serpent link and AE pivot ball)
#462
S100 and S120 took the win at the Utah state championships last weekend in mod 12th and WGT. What a sweet pair of cars.
#463
#464
Love the car . Keep up the great work
#465
