Serpent S120-Link
#197
Steve Dunn
#198
I have never put the serpent tubes on the on point chassis so the side to side movement I am not sure will let the pod move side to side. You may need to trim them if the pod side movement is not far enough. For shimming the ball studs 2-3mm on top of the cross brace and under the top deck should do it.
#199
#200
i have a artr car . its almost brand new , ran on carpet , let all your friiends know . tekin rs , speedpassion 17.5 , futaba , protek lipo , plenty of tires , tweek board .
http://www.rctech.net/forum/r-c-item...ml#post9492585
#201
There will be a conversion available from Serpent or parts separate.
The first batch of the updated S120L kit, the S120LT, is due to arrive at Serpent UK on 2nd October. The new kit features a damper tube style rear end instead of the previous monoshock design. The Serpent team have tested the new configuration extensively and find it to be more consistent and easier to fine tune than the previous design
#203
But Serpent very busy , can 2nd OCT release S120LT ?
end of this month release S811E !
#204
Check this out.
#205
WTF is that on the left is that the new car or your own creation.
P.S
Running the s120 link at FEMCA in Sydney and thursday practice had the car dialled no one could come close the the pace of the serpent.
Crashed into a stoped car on the straight and now car in 2 pieces
Built a new car couldn't get it to go like the last one but i have now found the problem tomorrow last 3 rounds of qualifying will post again soon and let you guys know how i go.
also ill post up a setup sheet tonight and we are racing on asphalt.
#206
Aaron Lee setup
This is what i ran at femca
#208
#209
Fastener Express
#210
