Like Tree1Likes
Polishing Crank
Old 11-08-2009, 08:02 PM
pyromania's Avatar
Trader Rating: 18 (100%+)
Default Polishing Crank
When I opened my engine up today I noticed that there was some rust carbon build-up on my crank. Is it ok to remove all the build-up by cleaning and polishing the crank?
pyromania is offline
Old 11-08-2009, 08:15 PM
mblgjr's Avatar
Trader Rating: 86 (100%+)
Yes, but it depends on what you're wanting to polish it with.
Gray, fine-grade Scotchbrite works well for the counterweight.
Most body shop supply places will have it.
http://www.rshughes.com/products/048011_04028.html
Combine with your favorite solvent and or/Dawn and hot water.
mblgjr is offline
Old 11-08-2009, 08:21 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
I usually don't bother polishing anything on a motor but I sometimes do a motor for other people and then I try to make it look a bit more professional. One of my favorite tools is a little paddle wheel sander from dremel. Real smooths and cleans up the face and edges of a crank nice. Not a mirror finish, you would need something finer for that but very nice.
As for the bore of the crank, I make little rotary sanders out of emery cloth and a dremel mandrel. Tricky to use in such a small hole (I learned this technique from sanding thumb holes in bowling balls) but works quite well.
wingracer is offline
Old 11-08-2009, 08:44 PM
pyromania's Avatar
I was thinking of first cleaning up the top layers of build-up w/ a toothbrush, then polish using some red rouge to finish it up.
Old 11-08-2009, 10:12 PM
Jesse Robbers's Avatar
Dremel makes a few different sized green color bits that work well for something like this where you just want to clean and not really remove material. They are rubber or sort of like rubber in material. Mothers mag & alum polish also works as a good 'cleaner' where solvents fail to clean carbon build up from top of piston.
Jesse Robbers is offline
Old 11-08-2009, 10:17 PM
merdith6's Avatar
Default Mothers aluminum polish
I really like the mothers polish, it works great on pipes, I never thought to use it for the inside of the engine. I also use it to polish hinge pins and shock shafts.
jersey likes this.
merdith6 is offline
Old 11-08-2009, 10:23 PM
Tech Prophet
houston's Avatar
Trader Rating: 96 (100%+)
use a wire wheel on a dremel
houston is offline
Old 11-09-2009, 02:22 AM
vti-chris's Avatar
On the crankshaft???
Will it affect it in any way?
vti-chris is offline
Old 11-09-2009, 06:48 AM
Integra's Avatar
Same here.
Integra is offline
Integra's Avatar
Not at all.
Integra is offline
Old 11-09-2009, 07:13 AM
pyromania's Avatar
Wow I never thought I would be able to use that. Thanks for the info guys.
Old 11-09-2009, 07:47 AM
Trader Rating: 47 (100%+)
Remember to cover the con rod pin with a short
section of fuel tubing before getting anything abrasive
near your crankshaft. If you mess up the con rod pin,
you've ruined your crank.
rageworks is offline
Old 11-09-2009, 03:58 PM
pyromania's Avatar
Yeah I know, the crank pin is no touchy touchy. I used the wire wheel w/ great success. Knocked everything clean off.
Old 11-09-2009, 04:07 PM
Tech Prophet
houston's Avatar
wirewheel is plenty small enough that you will easily be able to avoid the crankpin journal . you could cover for safety sake if you wanna really git jiggie wit' it though
houston is offline
Old 11-09-2009, 04:09 PM
Tech Prophet
houston's Avatar
i only say things because i have personally done it and been very successful.
houston is offline
