Castle Creations Mamba Max Pro Sensored ESC
#1096
Hi guys!
Sunday I ran with this Setup
Track: Carpet medium grip, track very driven, with many Chicane
Motor: Speedpassion V3 10,5, Timing +10°
Brake: 70%
Start power: High
Punch: disabled
C.E.A.T.H : mode on
Timing: 35°
RPM: 8000 - 17200
FDR: 6
With Fan: 50-60°
Without fan: 70°+
I'm Very Satisfied! good progression e very fast on the straight.
negative note, the brake is not strong, you say I try to increase the% of brake?
Brake: 70%
Start power: High
Punch: disabled
C.E.A.T.H : mode on
Timing: 35°
RPM: 8000 - 17200
FDR: 6
With Fan: 50-60°
Without fan: 70°+
#1098
The motor over heat a lot faster when it is under geared cause the motor works a lot harder to get up to speed. A lot of people try to gear lower to compensate with the timing on the ESC but most guys ended up frying their motor.
Few of my friends geared their car (17.5/13.5) at FDR around 7 or lower they are way undergeared so their motor temperature average at 260 degree comming off the track at the REEDY race with LRP X-12. When I told them I gear mine at mid 5 FDR motor come off cooler around 180-190 degrees. When they tried it the motor came off cooler and alot more efficient and faster due to less heat on the motor.
Try to find the sweet spot on the motor and leave it alone and maybe gear 1-2 teeth up or down depends on how big is the track. Changing your FDR significantly will just worsen your ESC/MOTOR performance. My 2 cents..
#1099
Hi guys!
Brake: 70%
Start power: High
Punch: disabled
C.E.A.T.H : mode on
Timing: 35°
RPM: 8000 - 17200
FDR: 6
With Fan: 50-60°
Without fan: 70°+
Brake: 70%
Start power: High
Punch: disabled
C.E.A.T.H : mode on
Timing: 35°
RPM: 8000 - 17200
FDR: 6
With Fan: 50-60°
Without fan: 70°+
I will hopefully have a X12 17.5 to try for saturday
#1100
Hi All
I got myself a MMP and just want to know what settings to try in cheat mode for 13.5 class or would someone share their settings. I'm running a 13.5 Ballistic motor.
Thanx in advance
Thanx in advance
#1101
Tech Legend
Trader Rating: 51 (100%+)
If you read back a few pages geeunit has some rough gearing for the 13.5 Ballistic motor and the 17.5 Ballistic motor. He just raced a big race last weekend and ran 13.5 using that motor and posted some results with running it.
#1102
HI!
Sunday I run With 4,5T SP V3 on this Track, Very fast
Rubber Tires
do you have setup to recommend me?
C.H.E.A.T. Mode ON() or Smart Sense?
Rubber Tires
#1103
