Xray T1
yes they do, but i'm not sure if the internal parts can be swapped...
Ok guys... i got the car hooked up nicely... just need to work on my driving skills... one big mechanical problem i am currently facing is the constant failure of the 3mm
plastic drive shaft caps... I am running a spool up front... every time i make a run, the plastic caps go a away... anyone else having this experience? suggestions? fixes...
any help will be appreciated...
Alien
Alien
Alien
Alien
That is the drawback of a spool, when you tap the wall there is no give and parts fail. Untill I am a mutch better driver, I will not use a spool. I have not tried this yet but have been told if you use a ball diff with no balls but install thin cardboard rings on both sides to fill in the gap and grease them, you can tighten it to almost work like a spool but it will have some give when you tap the wall.
Good day!
thanks guys...
I'm actually thinking about running the battery as should be on this car ( like angry-alien , perpendicular to the belt ), what do you think about the idea ?
Now after saying that, one racer in our club has his set up that way and it is working quite well. Different tracks, driving technics and car setups can make a large differance in how it will work.
Just try it and see how it works for you. I would put some velcrow on top of the battery and under the battery straps so the battery willl not slide.
Thanks for the advice ! I had it the modern way , battery on one side and electronics on the other side . I'll try this way so we'll see how it goes
Hey UrabusDenis, did you finish your build? can you post of some pics of the finished layout?
Alien
Alien
Sorry , not finished yet , here it's still winter and cold temperature with lots of rain , the outdoor season wont start until March I'm afraid so I still didn't start the rebuilt . It's all about 1:18 at the moment so 1:10 is collecting dust
Ah... okay... well let us see it when you are done... I recently added a few goodies to my Chassis, so I'll post them up soon...
Alien
Alien
Hey guys. I have some new in package T1 parts that have been sitting forever. Let me know if anyone needs em.
Front and Rear Arms
Sway bars
Steering blocks
Eccentric suspension holders
C hubs.
Front and Rear Arms
Sway bars
Steering blocks
C hubs.
PM me a list of these parts and the costing...
If he doesn't take them, let me know how much you want with shipping to Massachusetts. Thanks.
