Xray T1
Evo
I need a ultra rear shock tower like the one that came on the EVO, the problem is I can't find one. I went to stormer and the rcshack but no luck. Where else can I check online????
somebody???? anybody ????
i may have a couple in my parts box. I may even have one NIP. I will check when I get home this evening
cool
Cool man LMK. that's all I need. I found everything else. I just need that rear ultra tower.
lol. glad my avatar is getting around, that didnt take long
Originally posted by scmicromike
I have instaled a sway bar in the front. I want to know if when not in use, should I remove all the parts ot the sway bar or can I just remove the bar and leave the rest attached.
If you use the front one-way then you will definately want to keep the sway bar on there to help keep the rear tires stuck down.
I just installed the sway bars on my T1R this past weekend and they made a huge difference. I was cleaning the car up yesterday though and it looks like one of the mounts has moved a tiny bit and is rubbing on the axle just slightly. The wheel still spins for a while but not as long as the other side (one way). These things were a pain in the butt to install anyway. Someone mind posting a picture of their front end setup concentrating on the sway bar areas so I can see what I did wrong, if anything?
your welcome
Hey look there three avitars in a row!!! Dude, I can change it if you want????I normally don't high jack, but I liked it LMK
hehe its no problem, you can keep it. I made it because i didnt want to have the same xray one as everyone else here, at least now people have a choice if they want.
Cool
Thanks Qwiglee. I think I am going to try and move the mounts further back on the bar. all it needs is about a hair's width of movement I think.
I need a ultra rear shock tower still anybody ....help
