Like Tree3Likes
Xray T1
Old 02-18-2002, 06:31 PM
  #706
Buster Bennett's Avatar
Mike, Your welcome, sorry I was not available to talk when you came in.
Spongebob, I am sorry, I thought that site went over everything, I re-read it and noticed that it did not. You must shave off the underside of the plastic shock cap. The bottom of the cap will be totally flat when your done.
Buster Bennett is offline
Old 02-19-2002, 12:18 AM
  #707
Thistle's Avatar
Thanks Mike.
My computer couldn't find the internet page that you linked, but yeah, gluing it to the shaft would help. Right now, I have to open them to adjust them, which isn't as bad as it could have been.
Thistle is offline
Old 02-19-2002, 12:21 AM
  #708
David Galdo's Avatar
Trader Rating: 15 (100%+)
Originally posted by Thistle
Thanks Mike.
WOW! That is a messy task.
David Galdo is offline
Old 02-19-2002, 12:36 AM
  #709
Thanks Mike.
Here you go thistle:
http://www.ashfordhobby.com/tech02.h...ock%20building
The link is also on my post, 9 posts back.
Old 02-19-2002, 12:04 PM
  #710
Hello,
Anybody have a list of tools you guys used to build your xray. Example: what size allenwrench used for which parts?
pisnonvtec is offline
Old 02-19-2002, 01:02 PM
  #711
Trips's Avatar
Trader Rating: 16 (100%+)
2mm allen for all the chassis screws, droop screws, and motor screws
2.5 allen for the pillow balls and wheel bolts
3mm allen for the shock balls
5mm allen (I think) for the pillow ball retainers
1.5mm allen for setcrews and shock studs
Trips
Trips is offline
Old 02-19-2002, 01:36 PM
  #712
Trips,
Thanks I appreciate it. Now I will have to see if the lhs carries
hudy tools..
Old 02-19-2002, 10:57 PM
  #713
If your dealer will not carry Hudy stuff, email to [email protected] or check http://shop.hudy.net
mario is offline
Old 02-20-2002, 02:43 AM
  #714
Or contact me, I stock all Hudy products.
Old 02-20-2002, 08:44 AM
  #715
Mario & Buster,
I will let you know. I was told castle hobbies in san jose carries them. I will check what their inventory looks like.
Thanks alot.
Old 02-20-2002, 10:20 AM
  #716
mike_Webb's Avatar
I suggest calling Buster for the Tools. He has everything or he can get it very quickly.
Mike Webb
mike_Webb is offline
Old 02-20-2002, 03:44 PM
  #717
Peter Busch's Avatar
Will MIP O rings work on the bottom of the shocks or do I need to get the XRay ones?
Peter Busch is offline
Old 02-20-2002, 03:55 PM
  #718
mike_Webb's Avatar
I just measured my Blue ones that I have... I think they are MIP and they are the same size.
Mike Webb
Old 02-20-2002, 08:35 PM
  #719
Trips's Avatar
I needed to replace an o0ring in a serpent shock about a year ago, and the only thing that would fit was another Serpent o-ring. Everything else including the MIPs were too big.
Trips
Trips is offline
Old 02-21-2002, 12:37 AM
  #720
Thistle's Avatar
Thanks, my computer found the page this time.
I'll have to try the gluing idea. My problem isn't a stripped indent, it's the hole in the male piston is too loose on the shaft... I wonder if I could replace the top e-clip with a small nut to grab and hold it. Any ideas?
Thistle is offline
