Like Tree3Likes
Xray T1
Old 03-25-2004, 09:35 PM
  #6556
alana07's Avatar
Trader Rating: 53 (100%+)
Default T1R with short arms
hi there,
has anyone fitted the short arms to the composite chassis? if yes, what are the mods necessary besides the arms/mountings? is any dremeling/filing needed, does the steering servo mounting gets in the way? if so, what's the solution? many thanks....
alana07 is offline
Old 03-25-2004, 10:47 PM
  #6557
AdR|aN's Avatar
Originally posted by Neil Rabara
Be careful screwing in the Ti screws into the alum bulkheads. Without a barrier, the two metals will fuse.
So its not recommended? Sorry .. i am kinda ignorant to all this ... hope some guys would help
AdR|aN is offline
Old 03-26-2004, 04:39 AM
  #6558
sands's Avatar
You can use Ti screws, just oil them.
sands is offline
Old 03-26-2004, 08:14 AM
  #6559
AdR|aN's Avatar
Oil them? With? Is bearing oil suitable? Or bushing oil?
Or any kind of OIL?
TIA
AdR|aN is offline
Old 03-26-2004, 08:50 AM
  #6560
Neil Rabara's Avatar
Any type of oil. Place a drop in the hole before you screw in the screw. The oil acts as a barrier between the alum bulkhead and the Ti screw. Without the barrier, the metal properties will cause them to attract to one another in a process called cold fusion.
Neil Rabara is offline
Old 03-26-2004, 08:53 AM
  #6561
AdR|aN's Avatar
Thanks guys. Really appreciate it.
Didnt wanted to trash my car.
AdR|aN is offline
Old 03-26-2004, 09:31 AM
  #6562
AdR|aN's Avatar
Wow. Cold Fusion. Sounds very very Einsteiny!!!
LoL
Just joking. Appreciate your help
AdR|aN is offline
Old 03-26-2004, 09:52 PM
  #6563
I thought I had my short arm conversion complete but the cars been sitting in peices for a while. Tonight I was putting the servo back in and it doesn't seem to fit right. I want to make the servo arm parallel with the the top plate, but it seems that the only way I can make it right is to cut off part of the arm on the case of the my servo. Is this the only way to make the servo fit right? The only picture I've got to go on right now is: http://www.rctech.net/events/clevela...yrulxray_3.jpg which doesn't help a whole lot.
psbarger is offline
Old 03-26-2004, 10:17 PM
  #6564
rough512's Avatar
Trader Rating: 12 (100%+)
So that's why a buddy's been wrapping teflon tape around his TI screws
Anybody tried moving the cells forward a bit? most of the weight (cells and motor) are located at the rear, I was wondering if shifting the CG forward would help turn-in?
rough512 is offline
Old 03-26-2004, 10:48 PM
  #6565
AdR|aN's Avatar
I have tried 3 FRONT and 3 REAR combo on the car and its very very nice to drive. It gives your more front traction and this helps you in making the car turn in easier (not necessary faster).
But in the end, i when back to the original 3+3 saddle pack config and found it to be a more balance car.
Just my cheap 0.02 advice
AdR|aN is offline
Old 03-26-2004, 11:26 PM
  #6566
Default Lola 190mm body
Where can I find a 190mm Lola style body.....?
vadn1 is offline
Old 03-27-2004, 06:23 AM
  #6567
AdR|aN's Avatar
Default Re: Lola 190mm body
Is it available??
AdR|aN is offline
Old 03-27-2004, 02:58 PM
  #6568
sands's Avatar
You'll need to trim the bottom front servo tab so it will fit over the suspension parts. Or get some nylon blocks that you can custom drill to mount. I used some associated rc10 bocks and it works fine.
sands is offline
Old 03-27-2004, 02:59 PM
  #6569
sands's Avatar
I shifted the left side cells forward one slot. It made the transition into a corner more predictable by shifting less mass forward. Since more mass is already on the front tires, there is less to transition to the front.
Basically makes it smoother from power on to power off.
sands is offline
Old 03-27-2004, 04:41 PM
  #6570
Great, thanks for the confirmation before I hack up my KO servo.
psbarger is offline
