Xray T1
#5431
o, sorry i meant the original t1 nd the evo2 not the t1r. sorry.
#5432
#5433
Does anyone know of a editable setup sheet for these cars? Before I go hog wild and make a editable one I wanted to check.....
I assume most of you guys are running saddle packs...anyone have any luck with them on the left or right only?
Thanks !!
Thanks !!
#5434
Thanks !!
Thanks !!
#5435
how do u guys put ur batteries in your car?
i have my left batteries 2 slots up from the back. i was told it helps with weight distribution.
where bouts do u guys and what does it do. does it help with any handling?
#5436
Regional Moderator
Thanks !!
Thanks !!
http://www.msra-racing.com/pdf/Xray-evo2-chub.pdf
#5438
Thanks for the info guys. I do have the full versio of ADOBE and use it alot. Didnt know if anyone had one made. Thanks a ton...
Looks like I will be running saddle packs... oh well.. These looks to be muchbetter than the XX4 saddle packs..
#5439
well basically your config gives you more front traction...
#5440
Moving the weight more forward with also reduce the amount of weight transfer to the front during corner entry. This is a bit counter intuitive, but when there is more weight on the front to start with, there is less to transfer to the front.
So moving the bats forward is like running more positive rear droop.
Personally I have the batts all the way back, with about 1.5 mm droop using the "hold the tires down and lift the chassis" method. (about page 179 or so has a description)
I find that it is very sensitive to droop changes - I may move one side up one or two slots to see what it does. Then again I might just add a bit more rear toe to reduce the corner entry twitchyness.
I also haven't tried to move the rear wheels all the way back yet. Probably the easiest to change so I think I'll try this next.
Sorry - just thinking as I'm writing.
#5441
testing
test
#5442
Xray Carpet Setup
I am getting an Xray for Christmas and was wondering if anyone has a setup for indoor carpet. Also, should I use the adjustable or locked pistons?
Thanks for the info.
#5444
Bobby please tell your dad I dont have your number. Ask Him to call me..
Rafito
Rafito
#5445
rafito
hey whats up man? My dad says he doesnt have your number either if u want you can shoot him an email at [email protected]
peace
Bobby Llantin
peace
Bobby Llantin
