Help with BK2 / XXX swaybar
Hey guys. I got a swaybar set for my BK2 and was trying to install the rear one and it just doesn't go together right. When you tighten the set screw on to the bar itself, the ball gets cocked sideways because the hole for the bar is huge. The only way I can see to make this work would be to drill and tap the other side of the pivot ball for a second set screw.
Any thoughts?
Any thoughts?
When you hook it up, just try to keep the bar in the center the whole time as you tighen it down. Dont overtighen it so tight that it bends the bar like crazy. I really never had this problem so its hard to say.
