Novak Kinetic
#1276
The parameters indicated in the error message, Start RPM, End RPM, Boost Rate, Applied Timing and Turbo Mode are not listed as any of the parameters that I can see in the software. Where are they? Or are they the parameters listed on the advanced tab under different names? If they were out of range, I don't know where to alter the values. I'm not having that error message anymore, but it still begs the question, where are they?
How long does it take to update the settings? The blue circle just keeps going round and round. 15 min or so at this point. It never finishes updating.
I've got a 64bit Vista laptop that won't run the software, and an XP workstation that will update the firmware but doesn't seem to want to update the settings. I guess I'm screwed on both machines. 32bit app's are supposed to run on 64bit Vista, says MS, but Novaks site says 32bit only. I get Unhandled Exception errors when I try and do anything in the software. The program will open, I just can't do anything with it.
#1277
The blue circle is usually completed within 15-20 seconds, any longer or no completion message, I exit out and re-connect, when I do this the settings I have changed seem to be applied.
I really can't answer your computer issue, I use the cheapest notebook known to man, and truthfully, don't really run into many link/update issues, ie it works very well for me.
#1278
No it's not updating the settings. I go back in and the cutoff voltage keeps going back to 6.something volts. Do you get a small window pop up with an 'ok' button when you press update? In front of the blue circle? I called Novak this morning and noone returned my call. I guess I can set some of this stuff with the one touch programming, seems like a pain.
#1279
Remember that you have to do your change, such as the voltage and then tab or move to another box or it won't take your change, ie, select the voltage you want, then move to the drive freq box, like your going to do a change there.
I get no "ok" message when I do a update, I get the blue circle, when completed it says your sc has been updated and the screen refreshes.
Novak was still off today as where most companies because of new years. They should be back tomorrow.
Make sure that your running rdd.1.3 file in your Novalink folder, and have the right drivers installed.
#1280
Heres my modified carpet set up. 70X30ish track low 9 sec laps. Set up is very nice to drive, smooth, but has the rip when you get on the throttle and want to get moving
Ballistic 4.5 neutral motor timing
Drag brake 15%
Minimum drive 1%
Linear throttle/brake curve
current limit 2
Drive frequency 13.8
Start timing 7500
End timing 25000
Timing 8
No boost
8.8 FDR
Drag brake 15%
Minimum drive 1%
current limit 2
Start timing 7500
End timing 25000
Timing 8
No boost
8.8 FDR
#1282
I see no advantage as they are the same footprint and both have a cap that needs a lace to be mounted but, the 1s heat sink is lower but not by mutch and the cap I think is a little smaller. You would be ok with the 2s version. I use 2s in both my 1/12 and WGT and an original non lipo GTB in my 1/12 mod car without problems. I like you want a back up for my GTB's in the dirt cars should something go wrong and I need to pull one from the onroad cars. It makes good sense and I don't believe there is a price difference either.
#1283
Has anyone had any fires with their kinetic esc?
A young guy from our club was racing today at the racing lines international meeting in auckland, he had only done 3 laps when his kinetic caught fire.. it was so hot the wires melted off the esc.... this was basically his 1st race meeting with this speedy.
His gearing was 5.2:1 which is very slow for the track for 13.5t brushless, and there was no contact with any other car ...
The battery was a IP 5600 50c 2s lipo.... there was about 6 cars on track at the time.
just a note to all .be very careful with this esc?
#1284
My first one caught on fire and was a complete meltdown. No reason, it just gave up the ghost.
My replacement has been fine since then, touch wood.
#1285
K1S/K2S Info
For anyone that has done a update on either their K1S or K2S and has found that after their update the steering works but no throttle, try doing a ESC setup, then go back and do your profile changes. I had this happen to me last night, one time it gave me a calibration reset message, but another time it didn't.
Its a bit of a hassle since when you do the setup you default out of your custom profile, but at least the speed control isn't toast.
This has happened to me more times on the K1S, but has happened very rarely with my K2S as well.
#1286
This update requires you to update the firmware in the esc also.
Follow the link below
http://www.teamnovak.com/download/NovaLink/index.html
Adnan
#1287
Kinetic 1.4 update
NovaLink 1.4 Fixes:
- Added new & improved user interface
- Added data transmission correction to improve error correction
- Added RPM Trip Point for the Current Limit
- Added Timing Curve for a custom timing
- Added configuration options
- Added Windows 7 64-bit compatibility
- Fixed screen resolution issue with scrollbars
- Fixed all reported bugs as of January 6, 2011
Adnan
Adnan
#1288
Hi Guys,
I have downloaded the software and loaded on my comptuer, but I don't see the firmware on the web site to download.
Is there a link to the actual firmware?
Now I cannot use my speed controller, as I need 1.4 firmware to use the 1.4 software program. Please update quickly as I am racing in a few hours and want to test it. 1.4 software doesn't work with 1.3 ESC Firmware... means I might have to uninstall 1.4 software to and go back to 1.3 if it lets me...
More: Uninstalled V1.4 and installed V1.3 software but I have already used the Novalink device updater for V1.4, meaning I now cannot communicate with my ESC Firmware V1.3.
I am racing in 1.5hr, so again very disappointed. Guess I won't be making the race meeting unless ESCMAN updates the Novak web site with 1.4V Firmware.
#1289
We just uploaded the rev 1.4 to our web site please install this update on your pc and yes it work on Windows 7 64 bit.
Adnan
Adnan
Or are we suppose to use the 1s 1.4 beta firmware?
