Novak Kinetic
#511
While I understand that it can give you an idea of how efficient the esc is. And with that said they are all doing basically the same thing.
#512
try setting the current limiter to 3. for me this has dropped my temps 15* or more on average with no loss of power. Are u running TC or offroad. In TC choose the custom Thr. curve default 2. min drive at 10 drag start at 6. this has helped keep my temps near 140* on hot days in Sac. Ca where our track temp is usually 120*+. it gives the car good snap as well. if you are running 17.5 i have a killer set up let me know i will post up
#513
My link arrived today. I had some difficulty installing the software, but eventually got it.
Its a great way to program a speed control. I noticed my green brake light went away once I played with braking, but the action changed to how I wanted it, so I left it alone.
I mean this as a compliment for Novak. I'm not good with computers, and I dont care to be. Turn them on and they had better work...otherwise I throw them. I had no trouble changing values and applying them to the Kinetic.
Thank You for a great product. I was pulling wheelies with my sc10 and the 10.5 motor.
#515
Macdude try this I think you will like it
ballistic 17.5
fdr 5.0
55 timing
no boost
30 or N on motor
start 7250
end 13500
limiter 3
custom thr curve default 2
min drive 15
drag brk 8
this gives the car lots of pop from corner to corner with a 17.5. with a 60 foot straight top end really isnt an issue and boost off keeps temps down. let me know if this helps.
ballistic 17.5
fdr 5.0
55 timing
no boost
30 or N on motor
start 7250
end 13500
limiter 3
min drive 15
drag brk 8
#517
your getting hot because your undergeared. undergearing will make a motor hot just like overgearing will.
#518
#519
#520
ballistic 17.5
fdr 5.0
55 timing
no boost
30 or N on motor
start 7250
end 13500
limiter 3
min drive 15
drag brk 8
ballistic 17.5
fdr 5.0
55 timing
no boost
30 or N on motor
start 7250
end 13500
limiter 3
min drive 15
drag brk 8
#521
#522
Yea, I used them in my sc10. Gearing is 75/25. There are so many adjustments possible that it becomes difficult to decide what to do.
The timing boost is amazing. My green brake light wont light up once I change the braking curves, but the brakes work very well, so no big deal.
#523
ballistic 17.5
fdr 5.0
55 timing
no boost
30 or N on motor
start 7250
end 13500
limiter 3
min drive 15
drag brk 8
ballistic 17.5
fdr 5.0
55 timing
no boost
30 or N on motor
start 7250
end 13500
limiter 3
min drive 15
drag brk 8
I worked on it a little today. Did not have a chance to try the 5.0 FDR, I did lower the on motor timing 1 tick mark. I am running a DUO 2. That seemed to help some.
#524
with a Duo 2 make sure to temp often with these settings. the Ballistic motors seem to have more torq and easly pull these settings
#525
yes 5.0 on the fdr. if you will notice i use the motors torque to get out of corners and my start rpm is higher than other speedos. with this set up i am using more gear and less timimg in the infield thus producing less heat. here is my email i can send you my exact set up file for norcal if you would like to try it. [email protected] i also run this set up at speedworld and no other car had the same grunt in the infield as mine
