Novak Kinetic
#286
Same here, they better hurry up, the playing field is levelling up real fast, Tekin, LRP, SP/HW, CC are all fast in the right hands. I hope the delay is to add more grunt to the CPU (and hence some new tuning options or wider ranges compared to the others). Not to respin a fault that was found in the first production units.
#287
Company Representative
Some Kinetic Updates.....
We have added a small photo of our upcoming Kinetic 1S esc showing the RX pack harness that we install:
Novak Kinetic 1S Speed Control
We also decided not to offer the Kinetic 2S/Ballistic 540 Systems with the 3.5 and 4.5 wind motor options.
...(Kinetic 1S) is also wired for use with a 2S Li-Po receiver battery pack. Not only are these 2S receiver packs lightweight and easy to mount, but they also ensure the best possible radio performance – a great benefit to using the specialized Kinetic 1S.
*Advanced motor timing must not be used for 3.5 to 5.5-turn 540-sized motors
#288
How much longer is it until we see the 2S version released ?
#289
#290
#292
As a Tekin user I must say your user interface looks really nice and informative. I have a few questions:
Thanks!
- I see you have an ESC temp protection radio button, will you also have a motor temp button? If so, it would be nice to be able to set the temp cutoff levels for the motor.
- I see on the advanced screen you have a chart showing motor and ESC temps (NICE!). I see there are 17 samples. How far apart are these samples? Are they configurable?
- Is there any additional equipment needed to measure the motor temps? Or will the ESC do that through the sensor wire?
- What is Independent Drag Break, as opposed to regular drag break?
- With the "stock spec" versions of ESCs coming out, will there be a different version of software or just a radio button to change the ESC to "stock spec"?
Thanks!
#293
Thanks!
No, our earlier attempts to protect the racing motors from overheating were not acceptable to racers. Maybe a later version of the software can offer additional options.
Sorry, contact-- [email protected]
No additional equipment necessary.
There is no need for a "Stock Spec" Kinetic. Our Havoc Pro SC (on board timing adjustments, only) is aimed at those events for which high timing/boost is not required.
We are offering a Kinetic 1S optimized and wired for single cell racing
Thanks!
#294
Thanks for you answers. I wish the Kinetic offered a "stock spec" profile. I like the idea of one ESC to meet all needs. There will be times I may need to switch between the two, depending on car type/class. Your product and interface look real good though. Good luck...
#299
#300
- Novak GTB
- Novak GTB Spectrum
- Novak Slyder Drift
- Novak Havoc 1 Cell
- Novak Havoc Sport
- Novak Havoc Pro
