XRAY T3
#1216
That's rubbish. No car has toe built in the chassis plate anywhere. Xray is really going downhill with these quality issues. Perhaps they outsourced the manufacturing somewhere where quality isn't important.
#1217
Trader Rating: 20 (100%+)
T3 HAS rear toe-in built in.....1 degree. if you look on the setup sheet for rear toe, the option for shimming will show it... no shims allow 1degree of rear toe.
#1219
As for differences in rear toe, from left to right, the car was not built properly. The instructions for installing the front of the rear hingepin mounts, you must turn and hold as you are tightening the mount.... We have currently 15 T3 at our local track and everyone made sure the mounts were installed properly, so nobody had rear toe issues.....
hope that helps...
hope that helps...
#1220
Just finished building mine and all went together great.
Only thing I found was both rear arms tight after tightening up mounts.
Found I needed to file 0.2mm off the 2mm shims, was spot on after that.
The previous suggestion about loosening the crews underneath helped the front, but not the back.
Looking forward to running first time tomorrow.
#1221
Still as pointed out above the holes are misaligned and that's just down to poor workmanship. Why did Xray need to revisit this old design I am not sure, but chassis built in toe was last used a long time ago (TA02/03 anyone?).
#1223
Yeah, my "locating holes" are different distances from the edge of diff cut out. One is 5.21mm. The other is 5.49mm.
I won't know till I get this holder out (undamaged hopefully), but I wonder if I'll be able to tighten them with the arms installed, so they stay staight???? If not, will the one piece holder solve my issues? I doubt xray will give me a new chassis.
I have about 4 weeks till the Xmas break is over, so I still have time
#1225
It is very hard to get a good FDR in the slower classes with the 1.9, therefore you have to use tiny spurs to do it. There the advantages and disadvantages of each..
Antoni
#1226
[QUOTE=Sith Lord;6741863]Well, I got the screw out by drilling it out. Unfortunately because I used thread lock I don't think I can get the remains of the screw out. I'll need to buy another Arm Mount.
Warm up the mount with a micro torch. The treadlock should release and you will be able to remove the remains of the screw
#1227
or you can even use 25-30w soldering iron to heat up alloy mounts to remove thread locked screws
#1228
I am using 60w soldering iron to heat up the screw about 60sec to release the thread lock.
#1230
As you add shims at at the back for rear toe you are effectively making more of an angle between the pivot pin and the rear front metal pivot block.
Skiddins
P.S. the 'EU' stands for 'European Union' which Slovakia is a member state of.
The flag on the Xray boxes, blue with a circle of stars, is that of the European Union, not Slovakia itself.
