XRAY T3
#3226
Does anyone know if the new spec-R univaeral swing shaft will fit the new T3 2011 or not?
thanks!!!
http://www.rc-mushroom.com/product_i...ducts_id=21280
http://www.rc-mushroom.com/product_i...ducts_id=21282
thanks!!!
#3228
Spec R shorter so easy broke your SOLID AXLE DRIVESHAFT ADAPTERS !
#3231
thanks!!!
thanks!!!
#3232
#3233
#3234
xray t3 foam car versus rubber car
Hi
sorry for jumping in here but a easy question ,what are the differences between the two cars .I have a chance to grab up a foam t3 but generally I run vta ,are there drastic changes between them or is it just in the set up (suspension) ?????
hope you can help me out .
Thanks in advance
Matt
Thanks in advance
Matt
#3235
rubber spec has thinner chassis and the composite parts are a medium mix greating more flex....
foam spec has thicker chassis and the composite parts are a harder mix creating less fless.....(stiffer)
stiffer shock springs on the foam spec......and maybe sways aswell...
see the specs on thier website....
www.teamxray.com
www.teamxray.com
#3236
#3238
#3239
i ve got a spec rgear diff but i want to no what diff oils i should use for a asphalt track racing in stock
